WinX DVD Copy Pro Review: A Guide, Alternative & Comparison
Summary: Read this Winx DVD Copy Pro review If you want to copy your entire DVD collection to another blank DVD or make a digital copy to the ISO image file or folder for backing up or all device compatibility purposes.
It's time to save all of your old or new DVD content from being scratched or damaged. The best way is to copy them to any new DVD, or to enjoy them on any device anytime, you can make their digital copy to an ISO image file or folder. For doing this, Winx DVD Copy Pro is the ultimate program with its excellent DVD copying functions. So, in this comprehensive Winx DVD Copy Pro Review, you will also get an advanced alternative to Winx DVD Copy to excel your DVD coping experience.
Winx DVD Copy Pro Review: Introduction and Complete Guide
Winx DVD Copy Pro is a very renowned software used on Windows only to copy any DVD disc to another blank DVD or you can save it to your computer as an ISO image file or Video-TS folder. While copying DVDs, Winx gives 1:1 quality without any data loss. The copied DVD can be stored on the hard drive, cloud storage, external drive, or something else. WinX can handle all the common DVD formats, such as DVD-5, DVD-9, etc. It lets you copy DVD-9 to DVD-9 or DVD-5 to DVD-5 with lossless quality. So, let's get into the attractive features of this tool.
Features of Winx DVD Copy Pro
👍Pros
- It can remove any region code or copy protection such as APS, CSS, RCE, etc
- Lossless DVD copying option with a 1:1 ratio
- 9 dedicated modes to copy DVDs such as Full DVD backup, DVD title backup, ISO Mounter, DVD Burner, etc
- Using the DVD Info Display option and the internet, Winx can get all the information about DVDs from the authoritative DVD library
- While copying a DVD, it can fix bad sectors, read broken sectors, skip blank sector
- It let's you convert a DVD to MPEG-2 & copy audio, video, and chapter of the DVD
- It can handle all types of DVDs like TV series, music, workouts, 99-titles, homemade discs, etc.
👎Cons
- Winx DVD Copy Pro is not available for Mac
- It cannot support DVD-9 to DVD-5 copy
How to Copy DVD to DVD Using Winx DVD Copy Pro?
Step 1: After downloading the Winx DVD Copy Pro, you must install and launch it on your Windows system.
Step 2: Go to the Clone DVD to DVD Option > select the Source DVD & Target DVD Burner.
Step 3: Winx will automatically detect the inserted DVD> for multiple DVD drive users; you have to select the Browse option you need. Use the Browse button to select the preset Temp Folder.
Step 4: The Temp File destination must have more than 9GB clear space. Next, go for the optional settings such as Remove DVD region code, Remove UOPs, Remove CSS encryption, and Check Disney's fake.
Step 5: Hit Run next to initiate the DVD-to-DVD copying process. Now, for multiple users, select Burn from the pop-up window.
Step 6: For one optical drive user, the original DVD content will be backed up in the Temp folder, and you will get the pop-up box notifying you that the backup is complete. Next, you need to insert the blank DVD > and select Burn to complete the copying process.
Product Rating and User Feedback of WinX DVD Copy Pro
WinX DVD Copy Pro Rating
WinX has earned a solid rating of 4.4 out of 5 on TrustPilot, reflecting feedback from 363 users. Notably, 83% of these users awarded WinX a rating above 3 stars, highlighting a high level of user satisfaction and trust in the software’s performance and features. This suggests that, for the majority of users, WinX delivers reliable results and meets their expectations across various use cases.
However, it's worth noting that 15% of users gave the software a 1-star rating. Their reviews indicate certain areas of dissatisfaction, such as unmet expectations or technical challenges, suggesting that WinX may not be flawless for every scenario. By examining a range of authentic user reviews, we can gain a balanced understanding of both the strengths and potential drawbacks of WinX, helping you make a more informed decision about whether this software is right for you.
Users consistently praise WinX DVD Copy Pro for its simplicity and effectiveness. Many appreciate how quickly and smoothly it copies DVDs without loss of quality, noting that the intuitive interface makes it accessible even for beginners.
Users highlight its versatility—being able to clone full discs, copy main titles, or create ISO images—and commend its reliability in bypassing copy protections that often trip up other programs. Another common compliment is the stability of the software, with few crashes or errors reported. Overall, user feedback emphasizes that WinX DVD Copy Pro delivers exactly what it promises, making it a trusted tool for backing up and preserving DVD collections.
There are also complaints about the customer service, with some users experiencing slow or unhelpful responses when they needed support or refunds.
Some users on Trustpilot report that the ripping process with WinX DVD Copy Pro can suddenly stop or freeze before completion, especially with certain DVDs.
If you're looking for even greater reliability and a broader range of features in your DVD backup software, it may be worth considering DVDFab DVD Copy as an alternative. While WinX DVD Copy Pro offers strong performance for many users, DVDFab stands out for its ability to handle the latest copy protections, its frequent updates, and its more advanced customization options. These advantages make DVDFab DVD Copy a preferred choice for users who want a more powerful and stable DVD copying solution.
Dynamic Difference Between WinX DVD Copy Pro vs. DVDFab DVD Copy
While copying DVDs, you probably want to reduce the original file size to make all the files fit into one DVD or small device storage. However, Winx DVD Copy Pro can't compress files; therefore, you need ample device storage to save large files. So, while reducing file size, if you need extensive video editing functions, DVDFab DVD Copy is the best WinX DVD Copy Pro alternative.
You'll notice that DVDFab DVD Copy has received more positive feedback and fewer negative reviews compared to its counterpart. The feedback shows that DVDFab DVD Copy consistently receives more positive reviews, with users praising its reliability, powerful features, and ability to handle even the most challenging DVDs. In contrast, WinX DVD Copy Pro has faced more criticisms regarding stability and compatibility with newer protections.
To select the best tool for your DVD coping purpose with specifications and customization, you take a glance at the comprehensive comparison of these tools with their potential features and services.
Impactful Factors | WinX DVD Copy Pro | DVDFab DVD Copy |
OS | Windows Only | Windows & Mac |
Decryption | Yes | Yes |
Compression | No | Yes |
DVD format support | All major formats | All types of old or new DVD formats |
Batch Processing | No | Yes |
Metadata Synchronization | No | Yes |
The Advanced Alternative to WinX DVD Copy Pro: DVDFab DVD Copy
DVDFab DVD Copy can automatically detect and remove any copy protection without any hassle before copying DVD, such as CSS (Content Scramble System), APS (Analog Protection System), RC (Region Code), DADC, etc.
The most attractive function of DVDFab DVD Copy is to compress and reduce file size without compromising quality. It lets you take the lossless backup of any DVD to another new DVD/ ISO image file or folder. DVDFab can work on both the Windows and Mac devices. A dedicated Cloud Decryption Service can remove any old, new, regional, or other advanced encryption within the blink of your eye. So, let's see what are the main attractions of the tool.
👍Attractive Functions
- Lossless DVD copying with 1:1 ratio between DVD-9 to DVD-9 or DVD-5 to DVD-5
- Decrypt any DVD within a seconds
- Compress DVD file size with DVD-9 to DVD-5 coping support
- Compressed output files can be played on any portable or other devices
- Enjoy DVD-to-DVD conversion or digital copy in an ISO image file or folder
- 6 diversified copy modes such as Full Disc, Main Movie, Clone or Burn, split, merge, and customize in the DVD copying process
- Copy multiple DVDs in batches while keeping them in the queue, and they will be automatically copied one after another
- Save metadata while copying the DVD
- It can remove the Cinavia Watermark and enjoy audio in AC3 5.1.
How to Copy DVD to DVD Using DVDFab DVD Copy?
Step 1: After downloading and launching the DVDFab program on your Windows or Mac, go for the “Copy” Module from the left side module panel.
Step 2: Select Copy Mode > select any of the copy modes according to your choice from the available options > insert the source DVD that you want to copy into the optical drive. The tool will automatically upload the file.
Step 3: If the source file is an ISO image or folder, you can drag and drop the file in the main interface. After successfully uploading the source file, the main movie will be selected as the default setting.
Step 4: However, for more customization, you can change or select chapters, audio tracks, subtitles, etc. Head to the Advanced Settings option and select the output DVD file size as DVD-9 / DVD-5.
Step 5: Select the directory at the bottom of the main interface for saving the output file > from the drop-down list. Select the optical drive as the directory to save the output file to the blank disc. Next, click the Start option to initiate the DVD copying process.
Is WinX DVD Copy Pro free?
WinX DVD Copy Pro is not completely free. The software offers a free trial version that allows users to test some of its features, but access to the full range of functions—such as unlimited DVD copying and advanced copy modes—requires purchasing a paid license. The trial version typically has limitations like restricted copying capability or watermarks. For unrestricted use, users need to buy the full version from the official website.
WinX DVD Copy Pro takes around 12 to 17 minutes to copy any DVD. However, copying depends on your CPU strength, writing speed, DVD quality, etc.
In this WinX DVD Copy Pro review, you will find the detailed and dynamic factors of this tool. However, as your one-time investment in the most effective DVD copying software can save all of your old and new memories, movies, tutorials, or presentations stored on your DVDs forever, it's time to pick the right product. To enjoy the best DVD copying software on Windows and Mac, compress file size, or explore batch processing, you can try the DVDFab DVD Copy with its impressive time-ahead functions.
