How to Rip 3D Blu-ray to 3D MKV/MP4 in Easy Steps?
3D Blu-ray movies offers an immersive viewing experience far superior to standard downloads of 3D content. The incredibly vivid imagery and realistic depth of 3D Blu-rays transform any home into a personal cinema. But, how can you enjoy such enthralling content without a dedicated Blu-ray player or how to better preserve your 3D Blu-ray discs? Well, that's where the process of ripping 3D Blu-ray comes into play. This guide will provid you with an easy and swift process to digitalize your favorite 3D Blu-ray movies.
After thorough research, we have chosen DVDFab Blu-ray Ripper as our top recommendation for ripping 3D Blu-rays. Here are the key reasons why we believe it stands out:
DVDFab Blu-ray Ripper is a powerful 2D/3D Blu-ray converter that can convert protected 2D/3D Blu-ray disc, ISO file or folder to 2D/3D digital videos within several easy steps and at fast speed. It also contains some advanced features for you to customize your settings and edit the video.
💻Supported OS: Windows 11/10/8.1/8/7 & macOS 10.10 - 14
💡Key Features:
1. Keep updating to support the newly-released encrypted Blu-rays.
DVDFab Blu-ray Ripper can automatically remove any common Blu-ray copy protections: AACS, BD+, BD-J, RC, Country Code, etc. So you are able to rip any encrypted Blu-rays.
2. Rip 3D Blu-ray discs, ISO files, or folders to 1000+ 2D or 3D video formats.
Also Rip 3D Blu-ray to 245+ devices, including Huawei, Google, and Apple devices.
3. Preserve audio tracks, subtitles and all the metadata information.
4. Edit 3D Blu-ray videos by changing, cutting, trimming, cropping, combining, adjusting brightness, adding clips, watermarks, or subtitles using the built-in video editor.
Now let's have a look at how to convert 3D Blu-ray to 3D MKV, MP4, etc. with DVDFab Blu-ray Ripper for seamless playback on your 3D player.
Step 1: Launch DVDFab Blu-ray Ripper and Load Your Blu-ray
Run DVDFab Blu-ray Ripper and choose the "Ripper" module. Insert your 3D Blu-ray disc into the optical drive and navigate it through the Add button. If you want to rip a Blu-ray ISO or folder, simply drag and drop it onto the main UI.
Step 2: Choose a 3D Video Profile to Rip 3D Blu-ray
After the source is loaded in, the longest title, namely the main movie, will be selected by default. But here you can choose the chapters, audio tracks, subtitles, and define the names of the chosen titles.
Then, click "Choose Other Profile" to access the profile library. Here choose Format > Video > Filter, check the 3D option and choose a 3D MKV format. There several 3D MKV, AVI, M2TS profiles, just choose the one you want.
Step 3: Customize and Edit Your 3D Blu-ray Video
Go back to the main interface and you can further edit your 3D Blu-ray video. Click the "Advanced Settings" icon, you can set the parameters of video, audio and subtitle and choose the 3D format.
Click the "Video Edit" icon, you can edit the video with the built-in editor. This includes options to crop, trim, rotate, merge video clips, add watermarks and subtitles, and even adjust the color to fit your preferences.
Step 4: Select an Output and Start to Rip 3D Blu-ray to 3D MKV/MP4
Navigate to the bottom of the main interface and click the "folder" icon to select a directory to save the output video. Click the "Start" button to start the process of ripping 3D Blu-ray to 3D MKV video.
The DVDFab 3D Blu-ray Ripper utilizes GPU hardware acceleration technology to allow for a 50-fold increase in Blu-ray ripping speed. Additionally, this tool enables you to rip multiple 3D Blu-rays at once, streamlining the process with just one click.
Bonus: How to Play 3D Blu-ray?
Once you've ripped your 3D Blu-ray, there are now easier ways to enjoy your 3D movies. Here are some helpful tips for playing your converted 3D Blu-ray files.
- Use a 3D-capable Blu-ray player and 3D-enabled TV or projector, along with the correct 3D glasses.
- Ensure you use high-speed HDMI cables and connect to the proper input.
- For PC playback, choose software that supports 3D (like PowerDVD or DVDFab Player), and use compatible file formats (such as MVC MKV, SBS, or TAB).
- Consider audio equipment that supports HD formats for the best experience.
- For VR headsets, convert 3D Blu-rays to SBS or TAB format for playback via VR apps.
- Make sure all devices and software are updated, and consult device manuals for compatibility and troubleshooting.
In summary, DVDFab Blu-ray Ripper is an excellent tool to rip 3D Blu-rays to 3D MKV format. With its straightforward interface and powerful features, you'll be able to rip your favorite movies quickly and easily and enjoy it in a whole new way!
