How to Rip and Convert Blu-rays to Hi-Fi Audio Files in 6 Easy Steps
12/25/2020
If you are a music lover, you must have collected a lot of music Blu-rays. So do you want to convert your music Blu-rays to lossless Hi-Fi audio files (FLAC or WAV) and enjoy them on your top-notch acoustic system? Then you come to the right spot. This tip will show you how to rip and convert Blu-ray movies and music Blu-rays to Hi-Fi audio easily with DVDFab Hi-Fi Audio Converter. Read on for the detailed steps.
Step 1: Load a Blu-ray source
Run DVDFab 10, go to Ripper module, and load the Blu-ray source you want to convert.
Step 2: Choose a Hi-Fi audio format
Go to the profile library at the top left corner of the main interface, click format > Hi-Fi Audio, and then you can see there are 4 Hi-Fi audio formats. Just choose one you want.
Step 3: Customize your settings
The main movie title has been selected by default here, but you can also choose other titles. You are also able to change the title name, choose the chapters, audio track you want and set the audio parameters.
Step 4: Select a directory and start the ripping process
Move to the bottom of the main interface and click the “folder” icon to select an output directory. Then you can click the “Start” button to start the process of ripping your Blu-ray to Hi-Fi audio.
This tip shows you how to convert Blu-rays to Hi-Fi audio files, but if you want to convert Blu-ray movies to various video formats that can be played on your mobile devices, you can try DVDFab Blu-ray Ripper.
