"I really want to know how to burn MP4 videos to DVD on Mac so I can share them with my family on a big screen!" You're not alone if you have the same question. Many Mac users want a simple way to burn digital videos, such as vacation footage, family gatherings, or favorite movies, onto playable DVD discs. Although streaming and cloud sharing are now commonplace, physical DVDs remain a reliable option for offline viewing, gifting, and long-term storage.
This post will show you how to burn MP4 to DVD on Mac using the best free software and professional tools.
Burn MP4 to DVD Mac
How to Burn MP4 to DVD on Mac with the Best Software
Here's a comprehensive list of free and paid MP4 to DVD converters for Mac with powerful features to make the burning process effortless and hassle-free.
Burn MP4 to DVD on Mac with DVDFab DVD Creator
DVDFab DVD Creator is one of the best solutions for burning MP4 to DVD on Mac, and it ranks at the top of our recommendations. With the help of multi-core CPU support and advanced hardware acceleration, the software process data quickly without sacrificing output quality. It also offers useful features like customizable DVD menus, helping users create professional-looking discs with minimal effort.
💻Supported OS: MacOS 10.10-15 and Windows PC 11/10/8.1/8/7
👍Key Features:
  • Input 200+ video formats and make users enjoy high-quality DVDs.
  • Burn any video to DVD-5/9, DVD+R/RW, DVD-R/RW, DVD-R DL, DVD+R DL, ISO, or folder.
  • Allow for setting audio tracks, subtitles, output size, and quality.
  • Tailor output options, such as TV standards and aspect ratio.
  • Create stylish DVD menus using free menu templates.
  • Customize menu templates with personalized elements and widgets.
  • 50x faster DVD burning speed with GPU acceleration.
  • Preview your video at any time during the burning process.
How to Convert MP4 to DVD on Mac Using DVDFab DVD Creator
Step 1: Download and launch DVDFab 13. Choose the Creator menu from the left section and open the DVD Creator module.
How to Burn MP4 to DVD Mac Using DVDFab DVD Creator for Mac
Step 2: Tap the Add button to load your MP4 file on the main interface. Or drag and drop your MP4 video onto the program's homepage.
Step 3: Tap Advanced Settings and select your preferred output size and quality.
💡Note: DVDFab DVD Creator is a powerful tool for burning MP4 (and other video formats) to DVD on Mac with high quality. Here are the recommended settings for optimal results.
Category Recommended Setting
Video Quality Automatic (Best)
Bitrate Auto-adjusted
Aspect Ratio 4:3 (Standard) / 16:9 (Widescreen)
Audio Format Dolby Digital (AC3)
Playback Mode Start with the menu
Burn Speed 4x–8x
Step 4: Click the Menu Settings to access the built-in DVD menu maker. You can customize all the elements and widgets inside the templates, such as background images, thumbnails, text font, color, size, playback buttons, and so on.
Step 5: Pick the output directory in the Save to section. Tap the Start button for MP4 to DVD Mac. DVDFab DVD Creator will provide you with detailed progress information during the burning process.
How to Burn MP4 to DVD on Mac with Free Burners
1. DVD Styler
DVD Styler is an open source DVD burning software with multiple features to simplify the styling of DVD menus. It helps users create personalized menus using impressive tools or even choose one from readymade templates. Video enthusiasts can create professional-looking DVDs using this MP4 to DVD converter for Mac.
💻Supported OS: MacOS X up to 10.15 Catalina, Linux, and Windows PC
👍Key Features:
  • Easily create and burn DVDs on various platforms/devices.
  • Support many formats like MOV, AVI, MPEG, MP4, OGG, etc.
  • Provide a user-friendly interface with drag and drop facility.
  • Flexible menu creation based on scalable vector graphics.
  • Quickly copies any menu object or the entire menu.
👎Cons:
  • Prompt installation of the toolbar for ads.
  • Does not offer many features compared to other software.
  • The program lacks stability and occasionally crashes.
How to Burn an MP4 to DVD on Mac Using DVD Styler
Step 1: Tap the Add File button and import your MP4 files. Alternatively, you can drag your videos into the program.
Step 2: Now, add the menu by clicking DVD on your Mac's status bar and choosing the Add option. Then, select Menu.
How to Burn MP4 to DVD on Mac Using DVD Styler
Step 3: Choose the background and button.
Step 4: Then, drag your chosen MP4 videos to the menu. Double-click them to edit the properties.
Step 5: Put a blank DVD into your optical drive and start the Mac burn DVD from MP4.
How to Burn MP4 to DVD Mac Using DVD Styler
2. Express Burn
Express Burn is an easy-to-use MP4 to DVD converter for Mac that is available for non-commercial use; however, the free version can only be used to make audio CDs. On the contrary, a paid version enables you to burn DVDs and has advanced features. This DVD authoring software lets you burn videos to CDs, DVDs, and Blu-rays and create or manage the chapters for your DVD menus.
💻Supported OS: Mac OS 10.9 and above versions
👍Key Features:
  • Allow chapter creation
  • Allow dragging and dropping several files at a time directly
  • Help create MP3 CDs or Audio CDs for traditional CD players
  • Customize the pause between tracks when CD-burning audio
  • Effortlessly burn audio, video, and data files to CD/DVD
👎Cons:
  • Does not bypass copy protections when it copies DVDs/Blu-rays
  • Require a paid subscription to burn DVDs, as the free one burns only CDs
How to Burn MP4 to DVD on Mac Using Express Burn
Step 1: Download Express Burn disc burning software and follow the instructions to install the program. Then, insert a blank DVD into your device and launch the software.
Step 2: Select the type of disc you are burning. Then, choose video DVD and tap Create.
Step 3: Click the Add File(s) or Add Folder button in the top menu bar to add the desired MP4 files into Express Burn. Or, drag and drop your MP4 files directly into the program.
Step 4: Tap the Burn video DVD button to proceed with the burning process. You will see additional burn settings like write speed, burner drive, number of copies, etc.
How to Burn MP4 to DVD Mac Using Express Burn
Step 5: Once satisfied with the settings, tap Burn to initiate the burning process to DVD. Once complete, a popup will appear to confirm the burn process is successful.
Can you Burn MP4 to DVD on Mac with a Built-in Solution
1. Burn Data DVD on Mac with Finder
Finder is the default file management tool on macOS, and while it doesn't support creating video DVDs, it can be used to burn data DVDs. This means you can copy MP4 files to a blank disc for storage or file transfer, but the disc won’t play in standard DVD players.
💻Supported OS: Mac OS X 10.11 El Capitan or higher
👍Key Features:
  • Burn MP4 and other files to a data DVD without installing extra software
  • Useful for simple backup or offline storage
  • Pre-installed on every Mac and easy to use
👎Cons:
  • Burned discs are only readable on computers, not standard DVD players
  • No video menu, conversion, or authoring features
How to Burn MP4 to Data DVD on Mac Using Finder
NOTE: This method only creates a data DVD. The disc can store MP4 files but won't play on standard DVD players.
Step 1: Firstly, click your Mac desktop or open a window, and press File > New Burn Folder. A new folder with a burn icon will appear.
Step 2: Drag the MP4 files you want to burn into this folder. You can also add other files if needed.
Step 3: Once ready, Insert a blank recordable DVD (DVD-R or DVD+R) into your Mac’s DVD drive. Then, open the burn folder and click the Burn button. Choose the burn speed if prompted, then click Burn again to start the process.
How to Burn MP4 to DVD Mac Using the Finder App
2. Burn MP4 to DVD on Mac with iMovie + iDVD
tips icon
This method only works on older Mac systems (macOS 10.6 or earlier) that still support iDVD. Newer macOS versions no longer include or support iDVD.
iMovie is Apple's official video editing software, designed for Mac and iOS devices. Although it doesn't burn DVDs directly, you can edit your MP4 videos with iMovie and then export them to iDVD for disc burning. This workflow allows basic DVD creation with menus and themes, but it’s limited to outdated macOS versions.
💻Supported OS: macOS 10.6 Snow Leopard or earlier (for iDVD compatibility)
👍Key Features:
  • Streamlined design with intuitive editing features.
  • Create and fine-tune your movie.
  • Works seamlessly with iDVD for simple DVD menu creation.
  • Allows basic trimming, transitions, and text overlays before exporting.
👎Cons:
  • RiDVD is no longer supported on modern macOS.
  • Cannot burn DVDs directly from iMovie.
  • Requires manual export and file conversion for DVD compatibility.
How to Burn MP4 to DVD on Mac Using iMovie + iDVD
Step 1: Launch iMovie on your Mac and click the File menu in the top bar. Choose Import > Movies from the drop-down menu.
Step 2: Click the Share menu in the top bar and launch iDVD.
Step 3: Then, insert a blank playable DVD in your Mac's drive and click the Burn button. You can easily edit your MP4 videos and select a preferred DVD theme.
How to Burn an MP4 to DVD Mac Using iMovie
Best vs. Free MP4 to DVD Burner for Mac: Comparison Table
Feature/Software
DVDFab
DVD Styler
ExpressBurn
Finder (Mac) iMovie
Primary Use
DVD burning, video conversion
Free DVD authoring tool
CD/DVD burning File management Video editing
Supported Input MP4, AVI, MKV, and over 200 digital formats
MP4, AVI, MPEG, etc.
Audio, data, video All file types MP4, MOV, ProRes, etc.
Output Formats DVD-Video, ISO, folders
DVD-Video, ISO
CD/DVD, ISO N/A MP4, MOV, DVD( with iDVD)
Menu Customization Yes (templates & custom)
Yes (advanced customization)
No No No
Platform Windows, macOS Windows, macOS, Linux Windows, macOS macOS only macOS, iOS
Cost Paid (free trial) Free Free/Paid Free (built-in) Free (built-in)
Best For High-quality DVD burning Custom DVD menus & free use Quick disc burning File organization Video editing (no DVD burning)
1. Can I burn a playable DVD on a Mac for free?
Yes, but only with the help of free DVD burner for Mac like DVDStyler, which can create playable DVDs with basic menus. Built-in apps like Finder can burn data discs only, and iMovie requires the now-discontinued iDVD to create DVD-video discs. For best compatibility with DVD players, consider using professional software like DVDFab DVD Creator.
2. Can I burn an MP4 file to a CD?
Yes, but with limitations. MP4 files can be burned to data CDs, which are useful for storing files but cannot be played by conventional CD or DVD players. Express Burn allows you to do this, but for video playback, burning to a DVD is strongly recommended.
3. Does iDVD still work on Mac?
No. iDVD is only compatible with macOS 10.6 Snow Leopard or earlier. It no longer works on modern macOS versions like Catalina, Ventura, or later. If you're on a newer system, you'll need to use third-party DVD creation software instead.
Burning MP4 to DVD on Mac doesn't have to be complicated. We've discussed both free and premium macOS DVD maker software in this tutorial. Burn speed, output quality, compatibility with macOS, and functionality are all significant considerations when selecting tools.
If you need a more advanced alternative, tools like DVDFab offer professional DVD menu design and more stable performance.
