How to Convert VHS to DVD: Top 4 Simple Ways [2026 Updated]
Summary: The best way to convert VHS to DVD is to capture the tape as a digital video first, then burn it to DVD with DVD authoring software. A USB capture card with a computer gives the most control, a standalone converter box is easier without a PC, a VCR/DVD recorder works only if you already own reliable legacy hardware, and a professional service is better for many or fragile tapes.
Old VHS tapes often hold family videos, school events, weddings, travel clips, and other recordings that are hard to replace. However, VHS players are aging, blank tapes degrade over time, and it is becoming harder to play or share these memories on modern devices.
Transferring VHS to DVD still makes sense if you want a physical disc for playback, storage, or family sharing. The process can be simple or more technical depending on what you already have: a working VCR, a capture device, a DVD recorder, a computer, or only the tapes themselves. In this guide, I will explain the main ways to convert VHS to DVD, what each method requires, and how to burn a DVD after your VHS tape has already been captured as a digital video file.
Quick Answer: Best Ways to Convert VHS to DVD
The right way to convert VHS to DVD depends on what equipment you have and how much control you want over the final disc. If you want a flexible workflow, start by capturing the VHS tape to a digital video file with a USB capture card, then edit, back up, and burn that file to DVD with DVD authoring software.
| Method | Best For | What You Need | Computer Required | Output | Difficulty |
| USB capture card + computer + DVD Creator | Users who want editing control and a modern workflow | VCR, RCA or S-Video cable, USB capture card, computer, DVD authoring software | Yes | Digital video file, DVD disc, ISO, DVD folder | Medium |
| Standalone VHS-to-digital converter box | Users who want to record VHS without using a computer | VCR, RCA or S-Video cable, standalone converter box, SD card or USB drive | No during recording | Digital file, usually on SD card or USB drive | Easy |
| VCR/DVD recorder combo or separate DVD recorder | Users who already own working legacy hardware | VCR/DVD recorder combo, or VCR + DVD recorder + RCA/S-Video cables + blank DVD | No | Physical DVD | Easy to medium |
| Professional VHS transfer service | Users with many tapes, damaged tapes, no VCR, or no time | Your VHS tapes and a selected transfer service | No | DVD, USB drive, cloud download, or digital files | Easiest |
What You Need Before Transferring VHS to DVD
Before starting the VHS to DVD transfer, check your equipment and decide whether you want to create a digital file first or record directly to a DVD. This step prevents the most common problems, such as no signal, no audio, or a DVD that will not play on other players.
Basic Equipment Checklist
- VHS tape: Check whether the tape is cracked, moldy, or badly damaged before playing it.
- Working VCR: You need a VCR to play the tape. Test it with a short tape before transferring important videos.
- RCA or S-Video cable: RCA composite cables are common. S-Video may give a cleaner picture if both the VCR and capture device support it.
- Capture device or DVD recorder: Use a USB capture card, standalone converter box, or DVD recorder depending on the method.
- Computer: Required for the USB capture card method and for burning captured video files to DVD.
- Blank DVD: Use a reliable DVD-R or DVD+R disc if you want a physical DVD.
- DVD authoring software: Needed when you capture the VHS tape as a digital video and want to create a playable DVD.
Connection Types: RCA, S-Video, and USB Capture Card
Most VHS players use RCA composite output: yellow for video, red and white for audio. Some better VCRs also provide S-Video, which can reduce color bleeding and preserve a cleaner image. A USB capture card takes the analog signal from the VCR and sends it to a computer as a digital video feed.
Do not confuse a USB capture card with a DVD recorder. A USB capture card connects the VCR to a computer. A DVD recorder connects directly to the VCR and records the tape to a blank DVD without creating a computer video file first.
Should You Convert VHS to Digital First or DVD Directly?
Converting VHS to digital first is better if you want to edit the video, remove unwanted parts, keep an MP4 backup, upload the file to cloud storage, or burn more than one DVD later. Direct DVD recording is simpler, but it gives you less control and usually requires older hardware.
For most home users, the digital-first method is more practical today. You can keep the captured file as a backup and still create a DVD disc, ISO file, or DVD folder afterward. If your main goal is long-term file storage instead of disc playback, a VHS to digital workflow may be a better first step before DVD authoring.
How to Convert VHS to DVD: 4 Practical Methods
Method 1: Use a USB Capture Card and DVD Creator
The USB capture card and DVD Creator method turns an analog VHS tape into a DVD through a digital middle step. The VCR plays the tape, the capture card sends the analog signal to a computer, and capture software saves the recording as a video file. After that, a DVD Creator software like DVDFab can author the captured file as a playable DVD disc, ISO file, or DVD folder.
A computer-based VHS to DVD workflow gives you more control than direct DVD recording. You can trim unwanted parts, keep an MP4 backup, rename files by tape date, add a DVD menu, or burn more than one DVD for personal use. The trade-off is setup time: you need a working VCR, a USB capture card, a computer, capture software, and enough storage for the recorded video.
Important: DVDFab DVD Creator does not capture analog VHS tapes directly from a VCR. First, use a USB capture card or analog-to-digital converter to record the VHS video as a digital file. Then use DVDFab DVD Creator to burn that captured file to a DVD disc, ISO file, or DVD folder.
How to convert VHS to DVD with a USB capture card
Step 1: Connect the VCR to a USB capture card. Use the yellow RCA cable for video and the red/white RCA cables for audio. If both devices support S-Video, use S-Video for video and RCA red/white for audio.
Step 2: Connect the capture card to your computer. Install the driver and capture software if your device requires it. Open the capture software and select the correct video and audio input.
Step 3: Insert the VHS tape and play a short test clip. Check whether the picture, sound, and aspect ratio look correct. Most VHS tapes should be captured in 4:3.
Step 4: Record the full tape and save the file to your computer. MP4 or MPEG is usually easier to work with than a raw capture file.
Step 5: Open DVD authoring software such as DVDFab DVD Creator and burn the captured VHS video to a playable DVD, ISO file, or DVD folder.
Method 2: Use a Standalone VHS-to-Digital Converter Box
A standalone VHS-to-digital converter box records the VCR signal to an SD card or USB flash drive, so you do not need a computer during capture. The VCR connects to the box through RCA or S-Video cables, and the box saves the tape as a digital video file while the tape plays.
Standalone converter boxes suit users who want to digitize tapes first and decide what to do with the files later. The saved video can stay on a USB drive, move to a computer, or become a DVD through DVD authoring software. Compared with a computer-based capture setup, most standalone boxes offer fewer controls for editing, menus, file naming, and quality checks.
How to use a standalone VHS-to-digital converter box
Step 1: Connect the VCR to the standalone converter box with RCA or S-Video cables.
Step 2: Insert an SD card or USB flash drive into the converter box. Make sure it has enough storage for the full tape.
Step 3: Play the VHS tape and press Record on the converter box. Some models include a small screen, so you can monitor the picture while recording.
Step 4: Stop the recording when the tape ends. Check the saved video file before putting the VHS tape away.
Step 5: Move the saved video to a computer if you want to edit it or burn it to DVD.
Method 3: Use a VCR/DVD Recorder Combo or Separate DVD Recorder
A VCR/DVD recorder combo or a separate VCR plus DVD recorder is the most direct method if you want a physical DVD and already own the hardware. It records the VHS playback to a blank DVD in real time, so a two-hour tape usually takes about two hours to transfer.
This is now a legacy hardware method. New VCR/DVD recorder combo units are hard to find, and many users rely on used or refurbished devices. If you already have a working unit, this method is simple. If you need to buy one now, check the condition carefully before using it for valuable tapes. Besides, the finished disc often must be finalized before it can play on other DVD players.
How to transfer VHS to DVD with a DVD recorder
Step 1: If you use separate devices, connect the VCR to the DVD recorder with RCA or S-Video cables. If you use a combo unit, insert the VHS tape and a blank recordable DVD into the same device.
Step 2: Select the correct input on the DVD recorder. Play the VHS tape for a few seconds to confirm the video and audio signal.
Step 3: Press Play on the VCR and Record on the DVD recorder. Let the tape play in real time while the DVD recorder records it.
Step 4: Stop recording when the tape ends or when the part you want has been recorded.
Step 5: Finalize the DVD in the DVD recorder menu. This step is important because many recorded DVDs will not play on other DVD players until they are finalized.
Method 4: Use a Professional VHS Transfer Service
A professional VHS transfer service handles the capture process for you. You send or drop off the tapes, and the provider returns the videos as DVDs, USB files, cloud downloads, or other digital formats depending on the service package.
Professional transfer services are better for fragile tapes, large collections, or users who no longer have a working VCR. A service can also reduce setup mistakes such as no signal, missing audio, or failed DVD recording. Cost is the main limitation, so check the price per tape, turnaround time, accepted formats, copyright policy, and whether tape cleaning or repair is included before ordering. If your collection also includes 8mm or Hi8 tapes, confirm whether the provider can convert 8mm to dvd before placing an order.
| Provider | Current status | Starting cost | Turnaround | Output options |
| Walmart via YesVideo/Capture | Retail order route may be available through Walmart Photo | Starting around $15.96 for the first 30 minutes; each additional 30 minutes around $7.46; DVD around $3.96 per disc | About 3–4 weeks | Digital copy and DVD options |
| YesVideo / Capture direct mail | Direct mail-in service | Starting around $33.98 per tape up to 2 hours; promotions vary | Varies by order volume and season | Digital, DVD, or other options |
| Legacybox | Mail-in kit service | Often around $9–15 per tape during promotions; 2-item minimum | About 6–8 weeks | Digital download, thumb drive, DVD, or mixed packages |
| Southtree | Sister brand to Legacybox | Pricing is often similar to Legacybox | About 6–8 weeks | Package-dependent |
| Costco | Costco Photo Center services moved to Shutterfly in January 2023 | / | / | / |
How to Burn Captured VHS Videos to DVD with DVDFab DVD Creator
DVDFab DVD Creator works well after the VHS tape has already been captured as a digital video file, though it does not read VHS tapes directly from a VCR. DVDFab DVD Creator can take the captured video file and burn it to a high-quality DVD disc, ISO file, or DVD folder playable on your home media player. It also lets you add a DVD menu, adjust subtitles, and edit the video for storage or family sharing.
Step 1: Load the Captured VHS Video
Launch DVDFab and choose Creator. Select DVD Creator, then add the VHS video file that has already been captured and saved on your computer. Insert a blank DVD if you want to burn a physical disc.
Step 2: Choose DVD-5, DVD-9, Folder, ISO, or Disc Output
Open Advanced Settings and choose the output size and quality. Select DVD-5 or DVD-9 based on your blank disc and video length. You can also save the project as a DVD folder or ISO file if you do not want to burn a physical disc immediately.
Step 3: Add a DVD Menu, Audio, and Subtitle Settings
Use Menu Settings to choose a DVD menu template and adjust the background, title, buttons, and navigation. If the captured video includes subtitles or multiple audio tracks, check the settings before burning. You can also edit the video with the built-in Video Editor.
Step 4: Preview and Start Burning the Captured VHS Video to DVD
Preview the DVD structure before burning. After confirming the menu, video, audio, and output path, click Start to create the DVD disc, ISO file, or folder.
What is the easiest way to convert VHS to DVD?
The easiest method is a professional VHS transfer service if you do not want to handle equipment. For DIY users, a standalone VHS-to-digital converter box is usually the simplest computer-free option. If you want editing control, use a USB capture card with a computer and then burn the captured file to DVD.
Can I convert VHS to DVD without a computer?
Yes. You can use a VCR/DVD recorder combo, a separate VCR and DVD recorder, or a standalone converter box. A DVD recorder creates a physical DVD directly, while a standalone converter box usually creates a digital file on an SD card or USB drive.
Do I need to finalize a recorded DVD?
Yes, in most DVD recorder workflows you should finalize the DVD after recording. Finalizing writes the disc information needed for playback on other DVD players. Without finalizing, the disc may only play on the recorder that created it.
Should I convert VHS to DVD or MP4?
MP4 is better for long-term digital backup, editing, cloud storage, and playback on phones, TVs, or media servers. DVD is better if you want a physical disc that works in a DVD player. Many users capture VHS to MP4 first, then burn a DVD copy if needed.
Why does my captured VHS video have no sound?
No sound usually means the red and white RCA audio cables are not connected correctly, the capture software selected the wrong audio input, or the audio track was muted. Reconnect the audio cables, choose the capture-card audio input, and record a short test clip.
Can I still buy a new VCR/DVD recorder combo?
New VCR/DVD recorder combo units are very hard to find because VCR hardware is no longer widely manufactured. Most available units are used, refurbished, or old stock. Check the device condition, remote control, recording function, and disc finalization menu before relying on it for important tapes.
How long does it take to transfer VHS to DVD?
VHS transfer usually happens in real time. A two-hour tape takes about two hours to capture or record, plus extra time for setup, testing, DVD authoring, burning, and finalizing the disc.
Converting VHS to DVD is really about protecting recordings that may not have another copy. The best method depends on the tape condition, the playback device you still have, and how you want to watch the video later. Before recording a full tape, play a short section first to check the image, audio, and signal stability. If you capture the VHS tape as a digital file, keep that file as a backup before burning it to DVD. If you record directly to a disc, choose compatible blank media and finalize the DVD after recording. For valuable family tapes, the safest choice is the one that reduces tape handling and leaves you with a copy that can still be played years from now.
![18 Best Free DVD Burner Software for Windows [2026 Review]](https://images.dvdfab.cn/media/Best_Free_DVD_Burner_Software_for_Windows_16sgci.png/public)
![How to Convert MTS/M2TS Files to DVD: Tested 2 Methods [2026]](https://images.dvdfab.cn/media/How_to_Convert_MTS_and_M2TS_Files_to_DVD_phce29.png/public)
