Unique 4K to 1080P Converter That You Won’t Miss
Summary: In this article, you will know world’s first, best yet unique 4K to 1080P Converter that allows you to convert 4K UHD to Blu-ray with superfast speed and much higher quality than official Blu-ray, thus getting Blu-ray ISO/folder or a blank Blu-ray disc for playback on 4K media player or standalone Blu-ray disc. Read on to feed your sight on and master how to downscale 4K to 1080P.
• Convert 4K UHD Blu-rays to Blu-rays with the best quality
• Allow you to output Blu-ray in the format of ISO file or folder on HDD
• Make it possible to burn Blu-ray videos to a disc (BD 50/25) available on a home Blu-ray player
• Enable you to enjoy converted Blu-ray files on a player without 4K Blu-ray support
Do you know the true 4K to 1080P Converter? Is 4K better than Blu-ray? How to convert 4k to 1080p with lossless quality and fast speed? Many users put forward such questions on Google, Quaro and Reddit. This post will give you the best answers.
Reading Navigation:
- Is 4K better than Blu-ray?
- What is the Genuine 4K to 1080P Converter?
- How to Convert 4K to 1080P with High Quality
- Conclusion
1. Is 4K better than Blu-ray?
4K Ultra HD Blu-ray far exceeds standard Blu-ray disc in terms of storage capacity and peerless picture quality. Specifically, a 4K UHD disc has four times the storage capacity of a normal Blu-ray disc. A normal Blu-ray disc is BD25 which can hold up to 25GB of data. But a BD-100 (BDXL) can store up to 100GB of data. So you can calculate why it is four times the BD25 in storage specs. 4K UHD discs with HDR10 deliver ultra-high definition entertainment on a 4K screen, which is a top priority to any top-notch home theatre system where enhanced color and contrast, sharpest and most textured picture quality are needed.
But sometimes it may become a compulsion to downscale those 4K UHD discs so that they can be played on non-4K TVs, common BD players, 4K media player software aand devices like smartphones. In this article, we will discuss DVDFab UHD to Blu-ray converter – the best UHD to Blu-ray converter.
2. What is the Genuine 4K to 1080P Converter?
Though there are numerous so-called 4K to 1080P Converters on the market, you are suggested to tell true from false and make the right choice. As world’s first and only 4K UHD solution provider, DVDFab never let users down and develops the best 4K to 1080P converter, with official name DVDFab UHD to Blu-ray converter, as ever to meet user demand.
DVDFab 4K to 1080P converter as the name suggests is the best UHD to Blu-ray converter software for 4K UHD Blu-rays and ISOs which downscales them to fit on BD-25/50 blank Blu-ray disc. You also have the option to save the downscaled 4K UHD Blu-ray discs as ISO files and folders and you can also directly burn blank Blu-ray discs from within this software. The burned BD-50/25 Blu-ray discs can then be played on normal Blu-ray players with 1080p quality. 1080p Blu-ray resolution is the standard resolution that is supported by every Blu-ray player out there. So, the downscaled movie will not have any compatibility issues with any of the Blu-ray players.
As we know, 4K UHD movies are shot with a special camera feature known as HDR10 that enhances the video image quality to a lifelike quality level. Not all Blu-ray players recognize HDR10 from the 4K UHD discs. But DVDFab UHD to Blu-ray converter will downscale those HDR10 supported UHD discs in a way which doesn’t compromise the video quality too much and keeping the video quality as much best as possible. Here’s a step-by-step tutorial on using this software.
3. How to Convert 4K to 1080P with High Quality
We already gave you an introduction of DVDFab UHD to Blu-ray Converter - the best 4K to 1080p converter above. In this brief step-by-step tutorial, we will discuss how to convert 4K to 1080P fast and well so that 4K Blu-ray will be displayed with lossless quality on standard Blu-ray player.
· First of all download and install the 64-bit version of DVDFab 10. 32-bit version doesn’t support UHD to Blu-ray conversion.
· You should have a 4K UHD Blu-ray disc otherwise 4K UHD ISO will also work the same way.
· Open DVDFab 10 64-bit and click the ‘Copy’ tab. It will automatically load your 4K Blu-ray disc. If you aren’t using a disc then load an ISO by clicking the ‘Add’ button.
· Now just click the ‘Copy Mode Switcher’ button and select ‘UHD to Blu-ray’.
· Click ‘Choose Other Titles’ and select which titles you want to keep and which to skip.
· Click the video ‘Settings’ button to customize the settings.
· In the ‘Output’ either select ‘BD25’ or ‘BD50’ as per your requirement.
· You can also select options if you want a custom disc menu or no menu at all.
· Click ‘Custom Menu’ and a disc menu customizer and designer will open.
· Here you can customize the ‘text’, ‘background’, ‘add more images’, and drag and drop menu objects.
· After customizing the menu click the ‘OK’ button to go back to ‘Advanced Settings’ then click ‘OK’ again to return to main window.
· Now you have two options either burn the downscaled 4K Blu-ray movie directly to a blank BD25/50 disc or save an ISO file and burn it later.
· To save an ISO file click the ‘ISO file’ button and select the location where you want to save it. Check the second image above.
· If you want to burn a blank BD disc then insert a blank BD disc in to the Blu-ray optical drive and select the BD drive from the ‘Save to’ option.
· If you want to create and save those 4K UHD Blu-ray movies as a folder then click the ‘Save to’ option and select the default directory which is ‘Document>DVDFab 10’. Your downscaled 4K UHD Blu-ray movie will be saved here as a BD folder if you choose this option instead of ISO or direct BD disc write.
· After making your choice click the ‘Start’ button and wait till the conversion process completes.
· After the conversion completes you can play that BD25 or BD50 on a common Blu-ray player with 1080p resolution.
You have successfully learned to use DVDFab UHD to Blu-ray converter – the best 4K to 1080p converter and now you can convert all your 4K UHD discs to common Blu-ray format (1080p) and can even burn them or save them as a BD25/50 ISO or folder.
DVDFab UHD to Blu-ray Converter: Pros
· Save money on BD100 discs by downscaling the UHD media to fit in a cheaper BD25/50 disc
· The UHD downscaling makes the output Blu-ray format highly compatible with common Blu-ray players, gaming consoles, PCs, and BD ROM drives in laptops.
· While conversion it tries to maintain the best possible video quality. The HDR10 to SDR conversion is outstanding and no significant differences are seen on a 1080p HDTV.
· Lets you save the downscaled 4K UHD media as an ISO file of folder.
· Have a built-in Blu-ray burning engine. No need to look for third-party Blu-ray burning software.
· It only compresses the video but preserves the original lossless audio tracks.
· With Intel Quick Sync, Nvidia CUDA, and AMD Acceleration the conversion becomes really fast. All you need is the compatible computer hardware for faster processing.
Now you have understood what is the 100% true 4K to 1080P Converter and how to downscale 4K to 1080P without quality loss. Therefore, this is an in-depth review of the DVDFab UHD to Blu-ray converter. It is now your turn to test out this 4K to 1080P converter software. Don’t worry if you don’t have blank Blu-ray discs right now. You can choose the alternative and save your downscaled 4K Blu-ray movies as Blu-ray ISOs or folders. Blu-ray ISO files are easily recognizable by many media players. So, if you don’t want to burn your downscaled movies then you can just put those ISO files on a USB drive and can let your HDTV play it if it detects BD ISOs. So download the 4K to 1080P converter software and test it yourself, because it is free to use for the first thirty days. Later on you can decide to buy.
By the way, aside from playing movies downscaled from 4K to 1080P on HDTV, you can play them with world’s most professional 4K media player, DVDFab Player 6.
