Is AnyDVD Still Available?
2026 Update: AnyDVD Is Down!
AnyDVD developed by Slysoft software company was closed in 2016 but quickly returned as RedFox. However, both the redfox.bz official site and its software AnyDVD were gone in June. 2024, as users discussed on forums like Reddit and forum.videohelp.com. It is still unclear what exactly happened.
RedFox AnyDVD Review and its best alternative from DVDFab
AnyDVD has shut down, and that leaves three big gaps for disc collectors and home media users:
  • Mac users were left with no direct path forward.
  • Fresh UHD and studio schemes outpace legacy tools.
  • You still need extra apps to copy, convert, edit, or shrink discs.
Best AnyDVD Alternatives to Decrypt & Copy DVDs
Since RedFox AnyDVD is down, it is necessary to look for a top-rated alternative. DVDFab offers a single, stable toolkit that handles both Windows and Mac, keeps up with new protections including UHD/4K, and goes beyond decryption with copy, rip, edit, and size-down options (e.g., BD-50 to BD-25).
Upgrade Path 1: DVDFab All-In-One
🎯Target users/scenarios: Choose DVDFab All-In-One if you want one Windows or Mac application for decrypting, copying, ripping, compressing, and authoring discs. It suits users who save their collections to ISO files, folders, Plex libraries, NAS storage, or blank discs.
DVDFab is a long-established company with over 20 years of experience in software development and customer service. It provides the most comprehensive solution for DVD, Blu-ray, and UHD decrypting, copying, ripping, and authoring.
Best AnyDVD Alternative: DVDFab All-In-One
  • Support commercial and rental DVDs/Blu-rays/UHD, and recorded BDAV
  • Remove almost all old or latest disc copy protections
  • 1:1 copy DVD/Blu-ray/UHD to blank disc, ISO file or folder
  • High-quality compression from DVD-9 to DVD-5, BD-50 to BD-25, and BD100 to BD50 or BD25
  • Rip discs to MP4, MKV, MP3, and other digital formats
  • Burn MP4, MKV, and other digital formats to playble discs with stylish menus
  • Customize titles, subtitles, audio, resolution and file size
  • Enable GPU hardware acceleration along with batch copying of discs
💡DVDFab includes 28 versatile function modules to cover all your disc processing needs. Its Copy module mirrors all the functionality of AnyDVD HD, which allows you to decrypt any DVD/Blu-ray and rip them to unprotected ISO files or Folder. It also comes with additional features like copying discs to blank discs, compressing disc sizes, selecting audio tracks or subtitles, etc.
💡Moreover, DVDFab All-In-One incorporates other powerful disc processing tools. For example, its Ripper module allows you to decrypt and rip discs into 1000+ digital audio and video formats and its Creator module enables you to burn any videos to physical discs.
DVDFab offers a 30-day Free Trial! After it ends, limited free copying and ripping functions remain available for supported sources. Download DVDFab and try all its functional modules for FREE!
AnyDVD HD vs. DVDFab All-In-One
DimensionsAnyDVDDVDFab
Maintenance StatusDiscontinued; no updates since 2024Actively maintained
Supported OSWindowsWindows & Mac
Free Trial21 Days30 Days, with partial copying/ripping functions 100% free
PriceLifetime: €109 (≈$130)Lifetime: DVD Copy ($42.50), DVD Ripper ($59.49)
Disc DecryptionSome copy protections such as region codes, CSS, AACS, and BD+Removes almost all old or new copy protection (CSS, region code, RCE, APS, RC, DADC, Disney's Fake, AACS, BD+, RC, UOPs, BD-Live™, BD-ROM Mark, BD-J, CCI, etc.)
Input FormatCD, DVD, Blu-rayDVD, Blu-ray, 4k UHD Blu-ray, Video
Output FormatISO image / decrypted disc folderCopy Module: Disc/ISO/Folder.
Ripper Module: MP4/MKV/MP3, etc.
Creator Module: Disc/ISO/Folder
Copy Modes-6 copy modes in DVD
5 copy modes in Blu-ray
Compress DiscsNoYes
Select audio, subtitle and chapterNoYes
Video EditorNoYes
Hardware AccelerationNoYes
UpdatesIt is downSafe, clean, and constantly updated
How to decrypt and copy DVD/Blu-ray/UHD with DVDFab
Let's take DVDFab DVD Copy as an example to show you how to decrypt and copy a DVD. You can also copy a Blu-ray or 4K UHD Blu-ray with similar easy steps.
Video Guide:
Textual Guide:
Step 1: Download the DVDFab DVD Copy for free and launch the software.
Step 2: Insert the DVD you wish to copy into your computer's optical drive. The DVDFab software will automatically load the DVD's content. Alternatively, manually load the DVD by clicking the "+" or "Add" button or drag and drop the ISO file or folder onto the program.
How to decrypt and copy DVD/Blu-ray/UHD with DVDFab - best AnyDVD alternative
Step 3: Choose a copy mode suitable for your needs. Options include Full Disc, Main Movie, Clone/Burn, Merge, Split, and Customize. For this example, we'll use the "Main Movie" mode.
Step 4: Once the DVD's content is loaded, DVDFab will automatically remove any copy protection and sync all metadata. You can see the type of copy protection used by clicking the "Info" option.
Step 5: Choose your output as DVD-5 or DVD-9 and select the titles, chapters, audio tracks, and subtitles you wish to keep. Visit the "Advanced Settings" section to modify the volume label and output. Then, preview the content to ensure it's to your liking.
Step 6: At the bottom of the program, select a directory. This could be your optical drive for a blank disc copy, a selected folder on your hard drive for a DVD video folder copy, or an ISO image file copy. Finally, click the "Start" button to begin the lightning-fast DVD copying process.
Perfect AnyDVD Alternative with Powerful Feature: DVDFab Passkey
🎯Target users/scenarios: Choose DVDFab Passkey if you already use programs such as ImgBurn, PowerDVD, MakeMKV, or another backup application and want a Windows decrypter that works quietly from the system tray.
Similar to AnyDVD, Passkey All-In-One is also a disc decrypting and ripping software for Windows. It runs in the background, automatically removing all copy protections and region codes on DVDs and Blu-ray discs, making them available for playback or backup. However, Passkey supports more types of copy protections and also UHD Blu-rays and recorded BDAVs.
AnyDVD Alternative: DVDFab Passkey
Passkey All-In-One
  • Remove copy protection from commercial or rental DVD/Blu-ray/UHD.
  • Also compatible with recorded DVD/Blu-ray (BDAV/4K BDAV).
  • Regular updates to support new copy protection schemes.
  • Rip decrypted DVD/Blu-ray/UHD to unprotected ISO file or Folder.
  • Reset the region code of the player.
  • Customize your way with flexible configuration options.
  • Work with 3rd-party backup tools like DVDFab, PowerDVD, ImgBurn, and more.
The interface and usage of DVDFab Passkey are just as simple as AnyDVD. This perfect AnyDVD alternative offers a 30-day free trial, so download and try Passkey now!
  Free Download
  100% Safe & Clean
Buy Now
  Money Back Guarantee
Passkey All-In-One includes 5 product modules. You can purchase a complete Passkey All-In-One suit or each product separately as you like!
 Supported DiscsSupported Copy ProtectionOutput Formats
Passkey for DVDCommercial, Rental or Recorded DVDCSS, RCE, RC, APS, UOPs, ARccos, RipGuard, Region Code, CPRM, etc.ISO image file / Folder / DVD_RTAV
Passkey for Blu-ray & UHDCommercial or Rental Blu-ray/4k UHDBD+, 3D BD+, AACS MKB v 26, AACS bus encryption, Region Code, BD-Live, UOPs for Blu-ray, etc.ISO image file / Folder
Passkey for Blu-ray RecorderRecorded Blu-ray (aka BDAV disc)AACSISO image file / Folder
Passkey for 4K RecorderRecorded 4K Blu-ray (aka 4K BDAV disc)AACS, AACS2ISO image file / Folder
Passkey UHD Drive ToolSupported UHD optical drivesChanges compatible drive firmware when the installed firmware blocks UHD accessCompatible drive state; no media-file output
How to decrypt commercial discs using DVDFab Passkey?
How to use AnyDVD alternative: DVDFab Passkey
Step 1: Open Passkey software by double-clicking its icon. In the initial window, select either DVD or Blu-ray based on your disc type, then press the "Start Passkey" button. The program will then minimize to the system tray and begin detecting any disc inserted in your drive.
Step 2: Passkey will automatically initiate the decryption process. A status window will appear near the system tray, displaying a green progress bar. When this bar fills completely, the decryption is done. You can check detailed information about the disc by reopening the main Passkey window.
Step 3: If you want to save the decrypted movie, right-click the Passkey icon in the system tray and choose either "Rip to Hard Disk" or "Rip to Image."
profile
DVDFab Passkey All-In-One consists of five products and provides the free version: Passkey Lite. You can try any of the products you like!
RedFox AnyDVD Review: Why AnyDVD Was Ultimately Replaced
AnyDVD HD was a Windows device driver that decrypted supported DVD, HD DVD, Blu-ray, and UHD content in the background. Once a disc was processed, Windows and compatible applications could access it as though many playback and copying restrictions were absent. Its functions included region-code handling, removal of user prohibitions, and access for playback or backup software.
That background workflow remains useful, but the RedFox shutdown created several practical limits for anyone maintaining a current disc collection.
No Further Protection Updates: The final AnyDVD code and local key data remain fixed at their 2024 state. New discs that require an updated online database, Java-protection handling, or other revised decryption logic may not open correctly.
Windows-Only Support: AnyDVD never provided a native Mac version. Mac users have always needed a separate application rather than a direct AnyDVD installation.
Limited Standalone Output Control: AnyDVD focused on background access. Disc compression, detailed title selection, format conversion, and video editing generally required CloneDVD or another companion program.
UHD Hardware Requirements: 4K UHD workflows depend on a compatible optical drive and suitable firmware. This is not unique to AnyDVD, but the lack of current software and hardware updates makes troubleshooting older AnyDVD installations more difficult.
An activated copy may remain useful for older discs that it already supports. For newer releases or a growing Plex or NAS library, an actively maintained background decrypter or integrated copy-and-rip suite provides a more predictable workflow.
FAQs about RedFox AnyDVD HD
What Happened to Redfox.bz?
SlySoft shut down in 2016 following legal pressure from copyright holders and lengthy legal battles. Then, a new company called RedFox emerged, continuing the development of AnyDVD and other SlySoft products. It wasn't until early June 2024 that RedFox and its related products all disappeared from the Internet for no apparent reason.
Can I use an old AnyDVD installer without RedFox servers?
Yes, if you still have a compatible installer and a valid license key for that edition. AnyDVD did not require online activation, so a fresh installation can usually be registered locally with the saved key file. However, SlySoft keys do not activate RedFox 8.x versions, and an installer without a matching license will remain unregistered or trial-expired. Even a licensed copy may fail with newer Blu-rays or UHDs that require RedFox's unavailable online protection database or later updates. There is also no longer an official source for installers, new licenses, support, or updates.
Is AnyDVD Free?
Before RedFox disappeared, AnyDVD HD was sold as paid software and historically offered a 21-day trial. RedFox later listed a lifetime license at €109, but there is now no official purchase or trial channel.
Can I Use AnyDVD HD on Mac?
No, AnyDVD HD is a Windows-based software and isn't directly compatible with Mac. Alternatively, you can look for the above-mentioned software designed for Mac that offers similar functions as AnyDVD HD.
Is SlySoft Still in Business?
No, SlySoft is no longer in business. The company was shut down in 2016 due to "recent regulatory requirements". The company's assets and technologies were acquired and are now managed by a company called RedFox.
Is It Safe to Download AnyDVD HD from a Third-Party Site?
RedFox no longer provides an official AnyDVD installer, checksum, update channel, or support service. A third-party mirror may host an unchanged archived installer, but the original developer can no longer verify its integrity. Modified installers, cracks, and patch files add a greater risk of malware, unwanted software, or license tampering. Even a clean old installer will not receive support for protections released after development stopped.
Note: Avoid cracked executables and registry patches. Use software only with discs you own or have permission to process, follow local copyright law, and do not distribute copied content.
What is the Difference between AnyDVD, CloneDVD, and CloneCD?
AnyDVD was developed by SlySoft and later maintained under RedFox. CloneDVD is developed by Elaborate Bytes, while CloneCD originated at Elaborate Bytes before later becoming associated with SlySoft/RedFox. They each serve distinct functions:
  • AnyDVD is designed to remove restrictions on DVD and Blu-ray media. It allows for the removal of region codes and other protections such as CSS that prevent you from playing or copying the disc.
  • CloneDVD is used primarily for copying DVD video discs. It compresses long footage at high speed and very high quality. CloneDVD can also perform transcoding, which means it can change the format of the video data on the fly while copying to a DVD.
  • CloneCD is specifically designed for copying exact, 1:1 duplicates of your music or data CDs.
For best results, many users use AnyDVD in conjunction with CloneDVD. AnyDVD works in the background to remove copy protection, while CloneDVD is then used to make the actual copy of the DVD.
Here I have an in-depth RedFox AnyDVD review to help you learn the advantages and disadvantages of the AnyDVD HD. Moreover, if you want unlimited DVD decryption and backup, I also introduce you to the best AnyDVD HD alternatives from DVDFab, which is a safer and more stable software with better performance. Since AnyDVD HD is gone, DVDFab could be your best alternative choice to consider.
