How to Burn MP4 to DVD on Windows 10 and 11: 5 Ways in 2026
Summary: To burn MP4 to DVD on Windows 10 or 11, first decide whether you need a playable DVD-Video disc or a data DVD. Use DVD authoring software such as DVDFab DVD Creator, DVDStyler, or Freemake for a disc that plays in a standard DVD player. Windows Media Player Legacy only writes the MP4 as data, while Zamzar handles online file preparation but cannot burn a physical disc.
Here's the short answer: to burn MP4 to DVD on Windows 11 or 10 for a home player, you need DVD-Video authoring, not a copied MP4 data disc. A disc that works on a PC but fails in a DVD player was often saved as data instead of a VIDEO_TS structure.
Before choosing an MP4 to DVD burner, confirm that you have a writable optical drive, compatible blank media, enough temporary disk space, and a plan for DVD-5 or DVD-9 capacity. The original MP4 file size is not the deciding factor: runtime and target bitrate determine the quality tradeoff. This comparison separates playable DVD-Video authoring from an ordinary video-to-DVD burn and simple file storage.
| Tool | Input Formats | Batch Processing | Menu Design | Video Editor | User Ratings | Best For |
| DVDFab DVD Creator | 200+ video and audio files | Yes | Yes | Yes | 4.5 out of 5 from Trustpilot | Playable DVDs with menus, subtitles, editing, and ISO/folder output |
| DVD Styler | WAV, WMV, MKV, MPEG. AVI and more | Yes | Yes | No | 4.0 out of 5 from SourceForge | Free DVD-Video authoring and disc burning |
| Freemake Video Converter | Popular and non-protected formats | Yes | Yes (Limited) | No | 3.8 out of 5 from Trustpilot | Simple Windows DVD authoring and burning |
| Windows Media Player | WMA, WMV, AVI and more | No | No | No | N/A | Storing MP4 files on a DVD |
| Zamzar | Video, audio, images and documents | No | No | No | 4.3 out of 5 from Trustpilot | Preparing a small MP4 online before the disc-burning stage |
Burn MP4 to DVD on Windows 10/11 with DVDFab DVD Creator
DVDFab DVD Creator can burn one or more MP4 videos to DVD-Video instead of simply writing the original files to a disc. This gives the finished DVD the structure and navigation expected by a standard home DVD player. The same project can be written directly to DVD-5 or DVD-9 media or saved as an ISO image or DVD folder for later use.
The software also gives users control over the parts of the DVD that affect playback. You can match the TV standard and aspect ratio to the target player, keep the required audio and subtitle tracks, and add external subtitles when needed. Its DVD menu creator lets you build navigation for multiple videos or chapters, while the built-in editor can trim or crop footage before the disc is authored.
These functions are most useful when the goal is more than putting an MP4 file on plastic media. They let you prepare the video, navigation, subtitles, and disc size in the same project before sending the finished DVD structure to the optical drive.
💻 Burn MP4 to DVD on: Windows 11/10/8.1/8/7 and macOS 10.13 - 15.x
- Create DVD, ISO, folder from MP4, MKV, AVI, MOV, and more digital formats.
- Support DVD-9, DVD-5, DVD+R/RW, DVD-R/RW, DVD+R DL, DVD-R DL.
- Built-in Video Editor: Crop, rotate, add effects, and fine-tune videos.
- Customize DVD menus with free stylish templates, editable widgets & elements.
- Select audio tracks, subtitles, or add external subtitle.
- GPU-accelerated encoding for fast and high-quality DVD burning.
- Auto-sync metadata (title, chapter info, etc.) from source videos.
With its user-friendly interface and advanced features, this best MP4 to DVD burner allows you create professional-grade DVDs with just a few clicks.
Watch our quick tutorial below:
Step 1. Add MP4 Files to the DVD Creator
Click on the below button to download and install DVDFab DVD Creator on your Windows.
Free Download macOS 12 and newer
Once it opens, opt for Creator from the option bar and click the creator mode switcher to select DVD Creator. Load the video you want to burn via the Add buttons on the main UI. Alternatively, simply drag and drop it into the main UI.
Step 2. Customize the DVD Menu and Video Settings
Now you can choose the audio tracks and subtitles you want. If there are no subtitles in the video, you can add external subtitles.
You can also click the "Advanced Settings" button to customize your settings, like setting the file name, choosing the output as DVD-9/5, select menu properties and playback mode.
By clicking on the "Menu Settings", you can use the built-in DVD menu creator to select menu templates and customize elements like background image, thumbnails, font style and size.
After customizing the menu, click on the "Edit" icon (pencil symbol). This allows you to crop the frame, add subtitles, or apply watermark effects before burning.
Step 3. Start burning MP4 to DVD
Move to the bottom of the main interface to select an output directory. Selecting Optical Drive from the drop-down list box means burning MP4 to a blank DVD disk. You can also save it as ISO image file or folder. Finally, click the "Start" button.
Burn MP4 to DVD on Windows 10/11 with DVDStyler
DVDStyler is a free, open-source DVD authoring program for Windows, macOS, and Linux. It can place MP4 videos into a DVD-Video project and write the finished project directly to a blank disc, so it can create the type of DVD that standard standalone players expect rather than a simple data disc.
The program gives users more control over the DVD structure than Windows' built-in burning tools. You can arrange several MP4 files as separate titles, add multiple audio or subtitle tracks, create chapter points, and build an interactive menu from a template or your own background, text, images, and buttons. These controls make DVDStyler useful when you want a free burner but still need normal movie-disc navigation.
Its official news page lists version 3.2.1, dated November 2, 2021, so treat it as a legacy option and test the finished disc on your target player. It may suit users comfortable working with older software and custom menus, but it is less suitable when current maintenance and predictable hardware support are priorities.
💻 Burn MP4 to DVD on: Windows, macOS, and Linux
- Design a unique DVD menu or choose from ready-to-use templates.
- Able to modify the source code if they have programming skills.
- Can add multiple audio tracks and subtitle files to their DVDs.
- Lets users see how their DVD will look and function before burning.
- Includes built-in tools for encoding video files to the appropriate DVD format.
- The processing and burning speed of DVDs is slow.
- Requires indirect DVD burning by first creating an ISO.
- Has not been updated for a long time.
- May encounter failures in burning videos.
How to Create a DVD from MP4 Using DVDStyler:
Step 1: Create a New DVD Project
Insert a blank DVD, launch DVDStyler, and choose Create a new project. Set the disc label, capacity, video format, aspect ratio, audio format, and other basic project properties.
Step 2: Add MP4 Videos and Arrange Titles
Open the File Browser and drag the MP4 videos into the Titleset Manager. Arrange the titles in the order you want them to appear and check the project-size indicator as more videos are added.
Step 3: Create Menus and Chapters
Open the menu editor and choose a preset template or build your own layout with backgrounds, buttons, images, and text. Add chapter points when viewers need direct access to sections within a longer video, then preview the navigation before burning.
Step 4: Burn the DVD
Save the project, click the red Burn button, select the DVD writer, and start the job. DVDStyler can also create an ISO when you want to keep a disc image, but direct burning does not require that intermediate file.
Burn MP4 to DVD Format on Windows 10/11 with Freemake
Freemake provides a Windows-focused DVD burning function that accepts MP4 videos and prepares them as a playable DVD project. Instead of stopping at file storage, it lets users choose DVD output, add a menu, select PAL or NTSC, include subtitles, and send the authored project to a writable disc.
Its shorter setup can be useful when the main goal is to put several MP4 videos onto a DVD without spending time building a complex menu. The same project can also be saved as an ISO image or DVD folder, so the DVD structure can be kept before a physical disc is written.
Freemake currently offers version 6.0.1. Its free output carries a watermark limitation, so it may suit occasional Windows projects but not users who need watermark-free free output or macOS support.
💻 Burn MP4 to DVD on: Windows 11/10/8/8.1/7/Vista
- Support over 500 formats, including MP4, MKV, and AVI, to DVD-compatible files.
- Include editing tools such as trimming, merging, and rotating videos.
- - Upload to YouTube directly and convert videos optimized for various devices.
- Burn videos to DVD/Blu-ray, create photo slideshows, and extract audio from video files.
- Will add a watermark to the output DVD in its free version.
- Not suitable for Mac users or users with other systems.
- Limited access to advanced features such as creating menus, customizing DVDs, etc.
- The free version may have a slower burning process and frequent pop-up ads.
Steps to Burn MP4 to DVD with Freemake Video Converter:
Step 1: Add the MP4 Videos
Install Freemake on the Windows PC and click +Video to add the MP4 files. If the DVD will contain several videos, add them to the same project and arrange the list before setting the disc options.
Step 2: Choose DVD and Set the Menu
Click to DVD and review the DVD settings. Select the menu design, PAL or NTSC TV standard, audio options, and subtitles required for the project.
Step 3: Insert a Blank Disc and Start Burning
Insert a writable DVD, choose the optical drive as the output destination, and click Burn. If you want to keep the DVD structure without writing a disc immediately, select ISO or DVD-folder output instead.
Burn MP4 to a Data DVD on Windows 10/11 with Windows Media Player Legacy
Windows Media Player Legacy can write MP4 files to a data DVD without installing a third-party DVD authoring application. The MP4 remains an ordinary computer file on the disc, which makes this method useful for storage or for a device that already supports the video's MP4 container and codecs.
It does not build the VIDEO_TS structure, menus, or chapter navigation required by a traditional movie DVD. That means it is suitable when you only need to store MP4 files on physical media, but it should not replace DVD burning software when the disc must play like a normal commercial DVD.
💻 Burn MP4 to Data DVD on: Windows 11/10/8.1/8/7/Vista/XP
- Add MP4 files from your media library to the burn list.
- Burn audio CDs and data DVDs and save MP4 files as data.
- No extra download needed for basic data disc burning.
- Cannot create video DVDs that play on home DVD players.
- No DVD menus or chapter navigation.
- No video preview or editing options.
- No MPEG-2 encoding for traditional DVD playback.
How to Burn MP4 to Data DVD Using Default Windows Tools:
Step 1: Open Windows Media Player Legacy
Open Windows Media Player Legacy. On many Windows 10 systems it is already available, while some Windows 10 and Windows 11 installations provide it through Optional Features.
Step 2: Add MP4 Files to the Burn List
Insert a blank DVD and open the Burn tab. Open Burn options, select Data CD or DVD, and drag the MP4 files into the burn list.
Step 3: Start Burning the Data DVD
Click Start burn and wait for Windows Media Player Legacy to finish writing the files. A computer will read the result as a data disc, while a DVD player will only play the MP4 files if that player supports their video and audio codecs.
Use Zamzar Online Before Burning MP4 to DVD
Zamzar provides an MP4-to-DVD file option in a web browser, so it can prepare a small MP4 without installing DVD software first. The web service accepts files from a computer as well as supported cloud sources, and its current free service accepts uploads up to 50 MB.
The important limitation is that Zamzar does not control the DVD writer in your computer. It can process the uploaded file and return a DVD-format result, but it cannot insert or write a blank disc, create a customized DVD menu, or replace desktop DVD authoring software when the finished disc must play as DVD-Video in a standard home player.
This makes Zamzar an online preparation option rather than a complete MP4 to DVD burner. It is most relevant for small files when the user does not want to install software for the first stage, but a physical DVD still requires a writable optical drive and disc-burning software afterward.
- Supports 1,200+ file types.
- Works in the browser, so there is no need to install software.
- Simple steps for non-technical users.
- Free tier converts files up to 50 MB.
- Only supports files up to 50MB in its free plan.
- Free users experience slower conversion speeds, and large files may take longer to process.
- Batch conversion requires a paid plan.
- Ads appear in the free version.
How to Burn MP4 to DVD Online with Zamzar:
Step 1: Upload the MP4 File
Open the Zamzar MP4-to-DVD page and click Choose Files to upload the MP4. The free web service accepts files up to 50 MB, so larger videos require a paid plan.
Step 2: Select DVD in "Convert To"
Open the Convert To menu and select DVD as the target option.
Step 3: Run the Online Job and Download the Result
Click Convert Now, wait for Zamzar to process the file, and download the result. If the goal is a physical playable DVD, continue with a desktop DVD-authoring and burning program rather than treating the downloaded file as a finished disc.
How do I burn multiple MP4 files to DVD on Windows?
To burn multiple MP4 files to a DVD, use DVDFab DVD Creator. This MP4 to DVD burner can convert multiple video files to one DVD simultaneously and let you arrange the chapter order as desired. Here are the steps:
- Step 1: Install and open DVDFab DVD Creator. Select the "Creator" > "DVD Creator" option from the menu.
- Step 2: Click on the "+ Add" button or drag your MP4 video files into the program.
- Step 3: Rearrange their playback order by dragging them up or down in the list if needed.
- Step 4: Customize videos with menu settings and video editor.
- Step 5: Choose the output directory and click Start to burn your MP4 files to a DVD.
Can Windows DVD Maker burn MP4 to DVD?
No. Windows DVD Maker does not natively convert MP4 to DVD. It supports formats such as .asf, .avi, .dvr-ms, .m1v, and .mp2. You may be able to handle MP4 files with a codec package. Windows DVD Maker was included with some Windows 7 and Vista editions only. It is not available on Windows 8/8.1/10/11.
Can VLC burn MP4 to DVD?
No. VLC cannot create a Video DVD with the correct DVD structure. It can only transcode MP4 to other video formats, not a DVD. If you're technically inclined, you can convert MP4 to MPEG-2 with VLC via command line, then use extra tools to author the DVD structure, create an ISO from it (optional), and burn the ISO to a DVD with an ISO burner.
Why MP4 cannot be played on DVD player?
This is probably because your MP4 is encoded with a codec that your DVD player doesn't support. As a container format, MP4 can hold multiple video and audio codecs in it. Due to codec incompatible issue, you may hear the audio but can't see video, or you may get neither audio nor video.
Why does the burning software not recognize my external USB DVD drive?
Because modern laptops rarely have built-in disc drives, many users rely on external USB DVD burners. However, if you are using older, free burning software that hasn't been updated in years, it may lack the necessary drivers to recognize modern USB drives or Windows 11 systems, resulting in "drive not found" or "disc is not blank" errors. Upgrading to an actively maintained program like DVDFab DVD Creator ensures full compatibility with the latest external hardware and operating systems.
Why does my burned DVD look stretched or distorted on my TV?
This happens due to incorrect Aspect Ratio or TV Standard settings during the conversion process. Standard TVs use either an NTSC (North America/Japan) or PAL (Europe/Asia) format. If your software defaults to the wrong region, or forces a 16:9 widescreen video into a 4:3 frame, the image will look stretched or squashed. To fix this, always ensure your DVD authoring software is set to match your local TV standard and the original aspect ratio of your MP4 file.
To burn MP4 to DVD on Windows 10 or 11, select the method by the disc you need at the end. DVDFab DVD Creator, DVDStyler, and Freemake can author MP4 videos as DVD-Video and write them to a blank disc, while Windows Media Player Legacy is appropriate when a data DVD is enough.
Zamzar can prepare a small MP4 online, but it does not complete the physical disc-burning stage. If the DVD must play in a standard home player, author the project as DVD-Video and test the first finished disc on that player before burning additional copies.
![5 Top AVI to DVD Converters for Windows and Mac [2026]](https://images.dvdfab.cn/artifact/2026/10/19/HsCx2t8W3VyD6wHfogzkhte4XqgpBqdz/feature_cover.jpg)
