Guide on How to Use Handbrake
Summary: Handbrake is a handy software that is available as an open-source for the users. It can be used for a variety of purposes. With this Handbrake - How to use guide you will be able to use it for batch conversion, ripping DVDs, etc. So, let us get started with our How to use Handbrake guide to get you sorted.
Handbrake is a perfect tool that can be used for the conversion of video from any format and you can also select a variety of modern and widely supported Codecs on this software. It was developed in the year 2003 by Eric Petit and was used for ripping a DVD to a device that could store data. air this software can be used for hardware acceleration, transcoding, batch conversion, and converting an ISO image on a DVD or any other storage device which can also be a video_ts folder. now that you have got the information about it was fabulous software let's move ahead with Handbrake how to use guide and find out what more it can do.
How to use Handbrake?
What is Handbrake? Handbrake can be used for the conversion of videos from any kind of format and is an open and free source it can also work as a multi-platform software that can work on Linux, Mac, and Windows as well. But, there is a lot more than Handbrake can do, so let's find out how to use Handbrake in different situations to ease you with your work.
How to use Handbrake on Windows?
If you are looking for a way to use handbrake on Windows and thinking about How to use Handbrake as a video converter then you can use the following set of steps for the purpose:
Step 1: Selecting a video source
First of all, the user has to complete the downloading and installing process of handbrake for Windows and after launching it click on the source button given at the top. As soon as the user clicks on the source button they will find the following options:
File: It will be used as an option for the conversion of a video file to any format.
Folder: Under this option, the user needs to select a Blu-ray or DVD, video_ts folder on their desirable hard disk.
Now the user needs to go for the selection of a source and as soon as it is imported they need to go on a list of titles on the source and then proceed with the selection of that particular video that they wish to encode.
Step 2: Making the settings for output
In this step, you need to select the destination for output and you need to click on the browse button and need to choose a folder on your desirable hard disk.
After this, you need to proceed with choosing a preset from the given preset list on the right side and if you wish to customize the parameters you can N2 use the closest preset and then continue with changing from there. From “normal”, “high profile” and “universal” presets u may choose any as per your requirement.
Step 3: Conversion
After all the steps are completed you need to go for the final step of conversion. For this, you need to click on the button with start and code and this will start the conversion process from one format to another. In case you wish to convert more than one video then you need to click on the add to queue button and the “show queue” dialog will appear and your job is done.
How to Use Handbrake to rip DVD to PC?
If you are thinking about How to use Handbrake to rip DVD, then you need to follow the given steps:
Step 1: Downloading and installing handbrake DVD Ripper:
After downloading and installing the Handbrake DVD Ripper on your Windows PC e you need to follow the exact directions which will be available on your screen and then you need to proceed with the selection of sources which is given on the left-hand side of the window. the software can open Blu-ray discs, DVDs, Video_TS, ISO images, and BDMV directly.
Step 2: Scanning
Now handbrake will be able to scan your DVD titles and without taking much time it will rip the given DVD easily. If you are trying to encrypt Any DVD with several titles it may take a few more minutes to do the same. as soon as handbrake scans them one by one and finishes you need to click on the dropdown menu of the title and proceed with the selection of a written title for being copied.
Step 3: Choosing the right preset
Now you need to click on the dropdown menu of the preset and select the right preset from the list which mentions a lot of settings for devices, web, software, etc. Normally there are general presets mentioned in the software that makes use of MP4 format which is a widely accepted format and known for its quality and speed for conversion.
Note: Handbrake is not compatible to rip DVDs to the Video_TS folder and ISO images.
Step 4: Adjustment of video
Now you can do some adjustments to the video, subtitles, and audio mentioned under the presets menu. There are a few default settings that provide usability and good quality to the users. In case your DVD is having several audio tracks you can easily select your preferred one as per your requirement.
Step 5: Selecting the output
Now you need to specify the output to copy files. Herein you can click on the browse button which is present at the bottom of the window and proceed with specifying the directory where you need your output to be stored.
Step 6: Completing the process
In case you wish to copy more than one title in a single go then you need to click on the ‘add to queue’ tab which is given on the toolbar alternatively you can also click on the start and code button and this will start the process of ripping DVDs.
How to use Handbrake for Batch Conversion?
Step 1: Configuration of the output directory
After downloading and installing your Handbrake software you need to change the preferences of the program. For the very first time if you are trying to run a batch conversion of files you may receive a small error where the user needs to set a folder for saving their queue files.
Now the user needs to click on the ‘Tools’ and then go to the ‘options’ to open the section of preferences. Here you will be able to click on ‘ output files’ and then click on the ‘ browse’ button which is available next to the default path.
Now you will be able to select the folder where you wish to save your output files. As soon as you have decided where to save your videos you need to click the “ select folder” option and your job is done.
Step 2: Adding the desired videos to a Queue
Now you need to select your videos from several locations and add them to the queue one by one. Natively you can select a folder through file explorer where you will be able to browse the location where the source videos are stored. Here you can click on “select folder.” After your folder is selected, from the precepts option you need to click on the “the iPhone and iPad Touch” option or any other option of your choice and adjust the settings of output.
Now you need to click on the “Add to queue” option and select “Add all”. As soon as you are done you will notice that your files are adding up to the queue. This helps you in conditions where you wish to convert a good number of files in a single go. The Queue also offers a lot of options which you can choose as per your preference.
How to use Handbrake for adding video captions?
Step 1: Locating Required video files
First of all, you need to download the required video file or export it to prepare it for the order of the caption. If it is a lower quality version it will upload fast in comparison to the high-quality version.
Step 2: Ordering the caption file
If you are already having the subtitles for captions available with you in Rev, Download it SRT version from the section of captions editor in your Rev account.
Step 3: Downloading Handbrake software
Once you have completed the above-given steps you need to download and install the handbrake software from its official website.
Step 4: Opening video file
After clicking on the handbrake application you need to click on the open-source option and from the finder window, you need to open the video.
Step 5: Opening SRT File
Now you need to add your closed subtitle tracks or captions to this application. For this, you need to go to the subtitles tab, and then after opening the tracks dropdown menu you need to click on the add external SRT. from the finder window you can select the SRT file and can repeat the process as per your necessity for loading all the desirable closed caption or subtitle tracks.
Step 6: Choosing the right option
In case you wish to have your video file encoded with closed captions for any kind of subtitles you can easily skip this step where you require to choose “burned-in” for the open options.
Step 7: Exporting media file
As soon as your SRT files are loaded on the software air you can easily export the video from the Handbrake. For proceeding, you need to ensure the settings of audio and video tabs match to the source file are adjusted to the final export settings of your preferable output. Here you can also specify the location for export by clicking on the ‘browse’ option and saving the export name with the ‘save as’ option.
Step 8: Testing the subtitles
Now you can open your video in your desirable media player for testing the subtitle tracks. You can open it by using iTunes, VLC for quick time on your Mac device. In case you have burnt in your file of captions you will be able to see the rendered text on the video easily.
How to use Handbrake for compressing videos?
After downloading and installing the Handbrake software you need to open it and then follow the given steps:
Step 1: On the left side you will be able to see the ‘file’ option under ‘source selection.’
Step 2: Now you need to select the file of your choice that you need to compress and then click on ‘open’.
Step 3: After this, you need to choose where you wish to save your compressed video and need to click on ‘Browse’ for the same.
Step 4: Soon as you are done you need to enter a suitable name for your video to easily identify it between the original video and the compressed one. After this, you need to click on ‘save’.
Step 5: Under the output settings you will be able to choose the Mp4 format for the container.
Step 6: Now you need to click on the video tab and chose H.264 as the Video codec.
Step 7: Then you need to do the selection of a suitable preset from the option of the Preset Drawer. For high quality, you can choose Fast1030p 30.
Step 8: Now you need to select the correct frame rate which depends on the source of your video. In case it is NTSC is you can select 30 and make it 30fps. Here you need to tick the option of constant frame rate to ensure better compatibility for your video.
Step 9: Here you need to enter an average bitrate for your desirable video which must be between 5000 to 10000, and this also means that a higher bitrate will give you a higher quality of video and will take longer for uploading and downloading.
Step 10: Now you need to click on the picture and change the resolution or video frame size.
Step 11: You can also change anamorphic to none and the option of modulus to 16 then you can proceed with ticking on the ‘keep aspect ratio’ and by using the down arrow you can change the width as well.
Step 12: Now you need to select the audio tab in which you can choose the 48 ‘sample rate’ and stereo for ‘mixdown’. For ‘audio bitrate’, you can choose 320.
Step 13: In the final step you need to hit the ‘start encode’ button and now you can sit and relax till the video has finished compressing.
How to use a DVD decrypter and Handbrake?
If you are looking for an answer to how do I use Handbrake to rip a protected DVD then you can simply install libdvdcss for Handbrake software. After downloading you need to copy and paste the file of libdvdcss directly to the program folder of the software.
Alternatively, you can also download any third-party DVD Decrypter for the Handbrake software and you will be able to rip any copy-protected DVD easily. For more details, you can read the post Handbrake ripping DVDs.
Best Alternative to Handbrake
Handbrake is a good software but sometimes you may face bad quality in output video with it accompanied with scrambled video, pixilated results, and crackling sound. Moreover, sometimes it may make the video or audio out of sync.
If you are looking for the best alternative to Handbrake we have got a fabulous substitute for you. DVDFab All in one software has all that is lacking in Handbrake and also provides a lot of multiple features. Let us get an insight into what it can do for you.
DVDFab All in One
DVDFab all in one comes with a flat design with a light-colored theme and main function types available in the animated version. With this effective software, you will be able to clone or burn your DVD along with splitting and merging it. You can also customize it as per your preference. You can copy or convert a Blu-ray to a DVD format or vice-versa as per your convenience.
Features
- It has an enlarger AI that helps in the enhancement of video quality.
- Available for multiple devices such as Windows and MAC.
- Helps in copying, ripping, and burning DVDs.
- Assists in the conversion of DVDs along with Blu-rays and also works with 4K ultra HD blu-rays.
- Assists in working at a top speed and helps in exporting files without any loss in quality.
Price: $379.99 available at a discounted price of $265.99
Pros
- 30 days money-back guarantee.
- There is dedicated customer service that helps the user in multiple ways.
- Comes with a variety of options as copying, ripping, etc. in the case of a DVD.
Con
- No cons are available.
Steps to convert video with this software:
Step 1: As soon as you start the software you can go to its converter option and then on the left panel you need to click on the icon of profile in which AVI will be mentioned. then you need to open a profile library and go to the device option and you will be able to see the variety of supported mobiles. here you need to navigate through them and then choose anyone as per your preference.
Step 2: Now you need to click on the add button or you can also drag and drop the video file into the software for loading the source.
Step 3: As soon as you have completed the previous step you can change the audio tracks along with subtitles and also make use of the preview option with its fabulous settings in real-time. On the left side of the interface, you will be able to find the profile I can where you will be able to see the source info. Now you need to click on the advanced settings button and Virtually set all the audio and video parameters like frame rate, resolution, codec, and many more.
after clicking on the edit button you will be able to see a video edit window where you will be able to trim and crop the video and add any kind of watermark to it along with external subtitles.
Step 4: Now you need to click on the start button which is given on the main interface and this will start your conversion. When the process gets started you will be able to see detailed info of the progress in real-time and you can set your PC either to automatic shutdown or you can exit the program as well. See also: Handbrake for windows everything you should know.
DVDFab All in One is the best alternative to Handbrake.
Yes, Handbrake is open-source software that can be used on Windows 10 and Mac devices.
Yes, you can make use of DVDFab all in one software for 30 days as a trial version.
We hope that we were able to answer all your queries about How to use Handbrake on Windows 10, how to use Handbrake to rip DVDs, etc. with our Handbrake how to use guide. There are detailed steps for all your queries of How to use a Handbrake. Alternatively, we have suggested a better option if you find Handbrake inefficient in pulling out a task. DVDFab All in One is an efficient software that can be used in place of Handbrake and you will never be disappointed.
