Rip DVDs to MP4 With Best DVD Rippers 2021
Summary: Why do we need to rip DVDs? Why do we rip a DVD to MP4 format? Is there any efficient way to help me achieve this? If you are holding these questions on your mind, then go on reading this article to find the answers to them.
• Copy DVD and Blu-ray files with two backup modes: Full Disc and Main Movie
• Convert Videos/DVDs/Blu-rays to MKV or MP4 format
• Work at top speed and export files without quality loss
Before exploring how to rip DVDs to MP4 with the best DVD rippers 2020, we'd like to start from talking about the reasons that we need to rip DVDs to MP4. Now, let's start!
PART ONE: Why Do We Rip DVDs?
We need to rip DVDs out of different reasons. Below are some of them.
Reason 1: DVDs are easy to be damaged
I bet you must have the experience of losing your favorite DVDs because they are scratched. As we all know that little scratches on it may make the DVD unusable not to mention that they are so fragile that even your kids can break them without any difficulty. And once these situations happen, you will lose it forever unless you buy a new one.
Reason 2: DVDs take too much space
If you take a look at your shelf or room corner, you will aware that DVDs can take a lot of space. And it is hard to wipe off the dust on them. So to make your room seem more tidy or free more space to put other stuff without throwing your collected DVDs away, it is considerable to rip DVDs to MP4.
Reason 3: DVDs have region codes
Normally, almost all commercial DVDs have region codes. DVD region codes are a digital rights management technique designed to allow rights holders to control the international distribution of DVD releases. Therefore, only a DVD player with identical codes is permitted to play that DVD, which is so inconvenient.
Now, since we already knew the reasons for ripping DVDs, let’s step further and see why we rip DVDs to MP4 format given that there are so many other video formats out there.
PART TWO: Why Do We Rip DVDs to MP4?
MP4 is a container format for storing audio and video, as well as for other data such as images and subtitles. It has some advantages.
First, one of the major advantages of the MP4 format is that it is one of the most popular and widely-used formats on multiple platforms, thus making it easier to use and distribute.
Second, it has a high degree of compression while producing smaller file sizes, thereby making it ideal for video streaming or compressing high definition audio-video files.
Third, MP4 format can support metadata which means that the MP4 file can be integrated with 3D graphics, menus or user navigation options, and more.
Though MP4 format has so many good features, it doesn’t mean you have to and only can rip DVDs to MP4. Besides the MP4 format, MKV has also been put into the spotlight when it comes to converting DVDs to a digital format. So whether to “rip DVDs to MP4” or to “rip DVDs to MKV” or other formats, it completely depends on your need.
PART THREE: The Best Tool to Rip DVDs to MP4
Now, let’s talk about how to rip DVDs to MP4. Here we have rounded up the best DVD ripper software to help you. It is called DVDFab DVD Ripper.
Speaking of how to rip a DVD to MP4, we highly recommend you to try the DVDFab DVD Ripper software. To let you know this DVD ripper better, we have prepared its key features for you.
1. Key Features of the DVDFab DVD Ripper:
Compatible with both Windows and Mac systems
Decrypt protected DVDs automatically
Rip DVDs to MP4 format effortlessly without losing any quality
Convert DVDs to numerous video and audio formats, such as AVI, WMV, MKV, etc
Support a batch of DVD ripping
Accept DVD disc (2D&3D), DVD folder, DVD ISO image file
Co-work with Enlarger AI to upscale video images
Edit DVD videos, such as trim, crop, text, etc
2. How to rip a DVD to MP4 with the DVDFab DVD Ripper?
Step 1: Download and run this DVD ripper
After one-click of the downloading button, the downloading and installing process shall begin. And When it is finished, double click its desktop icon to run it.
Step 2: Add the DVD disc/folder
Select the MP4 format via a profile switcher. And then add your DVD disc if your computer has an optical drive. Otherwise, you can add a DVD folder by dragging and dropping.
Note: Make sure you do all the operations under the “Ripper” module.
Step 3: Edit the DVD videos
As we have mentioned, the DVDFab DVD Ripper not only support to rip DVDs to MP4 but also support you to edit them. In this step, you can choose video resolution, trim your video, or add text to it.
Step 4: Output your DVD video
Here comes the last step of ripping a DVD to MP4 which is to select an output location on the bottom of the interface and then click on the “Start” button. A short time later, your DVD videos will be digitized to MP4 video format.
Note: DVDFab has also developed the best Blu-ray ripper to give you a chance to enjoy your Blu-ray discs in a better way.
PART FOUR: Other Alternatives to Rip DVDs to MP4
VLC Media Player is also a robust media player that also allows you to rip DVDs to MP4 free. It is an open-source cross-platform multimedia player and framework that plays most multimedia files as well as DVDs, Audio CDs, etc.
1. Key Features of the VLC Media Player
Compatible on Windows, Mac OS X, and even Linux
No ads, no spyware, completely free for ripping DVDs
Play files, discs, webcams, and others
Shortcomings of the VLC DVD Ripper
Less straightforward to rip DVDs to MP4
Some errors can happen during ripping
2. How to rip DVDs to MP4 With VLC on Windows 10
Step 1: Open VLC and then choose the “Convert/Save”
Assuming that you already have it on your windows 10-running computer. Open it>find the Media tab>go to Convert/Save.
Step 2: Click on the Disc tab and choose the DVD option
As you finish step 1, an optional panel shows up where you can see the Disc tab. Select the DVD option under the Disc tab. And remember to check the box of “No disc menus” because VLC can sometimes get tripped up trying to convert a looping video menu. And you also need to find the location of your DVD drive.
Step 3: Click the “Start” button
A lot of things need to be done before starting the ripping process. First, click Convert/Save at the bottom>select the codec and particulars>click Browse button and choose an output location>press Save tab>click on the Start button.
Movavi Video Converter offers a one-click solution to help you rip DVDs to MP4. Besides software, it also offers an online-based video converter. Below are some other features of this DVD to MP4 ripper.
1. Key Features of the Movavi Video Converter
No quality loss, even with 4K videos
Batch processing of files of any size
Provide fast ripping speed
Easy editing and compression
Shortcomings of this DVD to MP4 converter:
There is one con of this converter you should aware of is that only 7 days free trial is available. After exceeding, you have to pay to continue using.
2. How to rip a DVD to MP4 with it?
Step 1: Add your DVD video file
To add your DVD files to the program, here are some operations you need to conduct. Open this DVD to MP4 converter> click on the Add Media button>go to Add DVD tab>select the Open DVD button.
Step 2: Set the parameters per your need
When your file is added, please head toward the Video tab to find the MP4 option. Then, preset the videos that best suits your needs.
Step 3: Start converting DVD to MP4
Click on the Save to button to opt for a location for the converted files, and then hit on the Convert button.
HandBrake is developed as a video encoding tool. With it, you can rip DVDs to MP4 free and get the result very quickly just by loading up a DVD video into the program.
1. Key Features of the HandBrake:
Rip DVD to MP4 free
Able to queue up multiple conversions
Compatible with Windows, Mac, and Linux
Shortcomings of this DVD to MP4 Ripper:
Can not handle DRM
Too complicated for the novices
2. Here are the steps you can take to rip DVDs to MP4 Windows 10.
Step 1: Install HanBrake and libdvdcss
To figure out how to rip DVDs to MP4 with it, you need to install HandBrake first. But this is not enough, because the libdvdcss also needs to be installed. You are required to copy the .dll file to your HandBrake program folder. Only after this way, the HandBrake can read your encrypted DVDs.
Step 2: Open the HandBrake program
After installation, you need to open this program which is followed by choosing the DVD drive from the sidebar that appears. Then, the HandBrake starts to scan your DVD which may take a moment. So a little patience is needed here.
Step 3: Chose the title to be converted
When the step 2 is finished, your DVD file will be opened. Then, you can select which title to rip via a dropdown box of the “Title”. Or, you can rip any special features. And don’t forget to pick up a location for your converted file.
Step 4: Preset your video
Some different output qualities are available. The higher quality the video is, the more space it will take. No question. So opt for one output quality in accordance with your need.
Step 5: Rip the DVD to MP4
When all things are well prepared, go to the top of the window to click the Start Encode button.
Freemake is a name synonymous with powerful, high-quality freeware, and this DVD to MP4 converter doesn’t let the side down. It is reachable for you to convert DVDs free. Here are some
1. Key features of Freemake Video Converter
Clean and clear interface
Rip a whole DVD or just parts of it
Doesn’t contain extra bundled software
Shortcomings of this DVD to MP4 ripper:
Freeware only available on Windows
The latest version has watermarks to videos
Some features require activation
2. Steps to rip DVDs to MP4 on Windows 10 with it
Step 1: Download and run this free DVD to MP4 converter
It should be noted that this free DVD to MP4 converter is only available on Windows right now. Besides, an online installer of this converter shall get along with it by default.
Step 2: Add DVD to the converter
Insert a DVD into the disc drive to extract it to the computer. Then start the converter>click the “+DVD” button at the top row>select your DVD drive with disc>choose a VIDEO_TS folder.
Step 3: Set parameters
Choose the MP4 format, and then set its related parameters, such as codec, frame size, bitrate, music parameters, and others.
Step 4: Rip DVD to MP4 free
Start ripping DVD to MP4 by clicking that “Convert” button. The conversion process will take some time depending on your PC capacities.
MakeMKV is a refreshingly frill-free DVD ripper that can be used on Windows, Mac OS, and Linux systems. It is completely free to use while it’s in a public beta. During the process of ripping DVDs to MP4, there is little to think about for users.
1. Major features of it.
Quite simple to use
Friendly for the beginners
Works with Blu-ray discs
Shortcomings of it:
Few customization options
Can not deal with all encrypted discs
Take a long time to rip
2. Steps to rip DVDs to MP4:
Step 1: Launch MakeMKV
Insert a DVD disc in your optical drive, then click the big button that looks like an optical drive. As a result, MakeMKV will read the disc automatically, then display its contents.
Step 2: Set your DVDs to be ripped
You can choose to exclude different parts of a disc by clicking the disclosure triangle next to the disc.
Step 3: Initiate the ripping process
Click on the MakeMKV button to initiate the ripping process.
In the End
Whenever you need to rip DVDs to MP4, among all these rippers above, we still highly recommended the DVDFab DVD Ripper based on our testing and the review of users' experience. Now, just take action to rip DVDs to MP4 so that you can enjoy all your DVD movies at your fingertips on every electronic device.
