VHS, the abbreviation of video home system, is considered a prevailing tool in the 1980s to 1990s. until the appearance of VCD, DVD, and Blu-ray. At that time, a majority of people choose to use camcorder tape or VHS cassettes to record certain important information or keep valuable moments.
Nowadays, there are still a great number of people still maintain these issues for a wide range of purposes such as nostalgic value, ease of use in recording, keeping personal videos or home movies, watching content currently exclusive to VHS, and collecting.
However, as the original modes have been replaced by edgy technology, users are in desperate need of the best VHS to DVD Converter to remove their memories into a better form, for the magnetic tapes will decay quickly, even if stored carefully.
Solution 1: VHS to DVD Conversion Services
vhs to dvd
For those who are not familiar with the VHS to DVD Conversion process, turning to some big-name retail corporations for help is a relatively good choice. Stores like Costco, CVS, Walmart, and Sam’s Club provide conversion services.
Users are allowed to transfer up to two tapes to a single DVD disc before paying extra money. Additionally, companies like Legacy Box offer similar services as long as you are able to ship VHS tapes yourself at a more affordable price.
Solution 2: Convert VHS to DVD with VCR and DVD Burner
vhs to dvd converter
The best VHS to DVD Converter is a must-buy for anyone who owns plenty of camcorder tapes or VHS cassettes. These kinds of converters are easy-operated and affordable. You only need to connect it to your video recorder or camcorder and transfer them to DVD, then you could easily review these memories with PlayerFab DVD Player.
Necessary Items for VHS to DVD Conversion
  • A VCR
You could find your old machine or buy a second-hand tool for VHS to DVD conversion. Before using, there are some steps to finish.
Firstly, check your VCR to ensure it is able to work. Useless cassettes could be used to check.
Secondly, clean the machine. A thorough cleaning is beneficial for the VHS to DVD conversion.
  • Review the Tape
One of the most important items is the tape, for it probably hasn’t been touched for years. Therefore, please pay extra attention to its conditions, whether it's tangled, moldy, broken, or bent.
For partial crunchy tape: if you are lucky enough, you will get a partial crunchy video. If it's found, use your finger to wind the tape and check the damaging area. If the crunch is in a small space, use cotton or soft clothes to straighten the tape. Do it carefully so that it can restore its old position.
For tangled condition tape: to detangle the tape, you need to open it with a small screwdriver and fix it yourself. It's time-consuming work, and it requires patience.
For musty condition: It's expected when you are dealing with an item 25 years old. It will affect the VCR, too, if you use musty tape. If you find the tape condition is stale, you must clean it before pushing it inside the VCR. The cleaner is available; buy it and clean it after thoroughly checking how much the fungus damages the area.
  • A DVD Burner
VHS to DVD converters are normally bundled with software that allows you to use them. With pricier devices, this software often includes editing and DVD burning tools as well.
How to Convert VHS to DVD?
1. Set and connect the machines
You can hook up the DVD recorder to the VCR by plugging a set of RCA audio/video cables from the VCR’s RCA outputs to the DVD recorder’s RCA inputs. On some models, you might need an RCA-to-HDMI converter to connect the two.
This is essentially the same process you’ll need to use if you’re using a VHS camcorder as your playback device — simply connect the camera’s outputs to the DVD recorder via the RCA cables or, if necessary, the RCA-to-HDMI converter we just mentioned.
2. Begin conversion
Pop a tape into the VCR and a blank DVD+R or DVD+RW (some units only accept one of these formats, so double-check that) into the DVD player, then begin the transfer process. The method differs between models, but it should be relatively straightforward, and generally involves starting the recording mode on the DVD recorder, followed by pressing play on your VCR or camcorder.
You could follow the instructions of the manufacturer or search on Google, all of the necessary information can be found. Most DVD Burners have two phases: recording and finalizing. In the recording mode, as long as you didn’t run out of storage capacity, you are allowed to add footage to a single disc. Once finalized, a disc cannot be used for any further recordings.
Solution 3: Convert VHS to DVD, Blu-ray, or Digital Formats
As technology grows by leaps and bounds, playing videos in digital forms gradually gains popularity due to its convenience. You could watch your vital moments on devices such as anywhere and anytime you want, or uploading the videos to streaming platforms to share with your happiness is a good choice. With digital formats, there is no need for you to worry about the loss of videos. Let’s have a look at the best tools to complete the conversion of VHS to DVD.
DVDFab DVD Creator
Operating system: 11/10/8.1/8/7 (32-bit/64-bit), Mac
Price: $24.99
In this part, you need to use an analog-to-digital video converter to convert VHS to digital video files first and then burn them to DVDs. This approach of converting VHS to DVD although may take more time, it gives you options to deal with your videos.
  • Auto-display metadata info of videos
DVDFab DVD Creator is able to synchronize the metadata information including cover, posters, cast, rating, category, and description in the process of burning videos to DVD. Hence, users could easily gain access to comprehensive info in order to have a better watching experience.
  • 20x Faster Conversion Speed
Have you ever waited for the process for a long time? DVDFab DVD Creator’s multi-processing function promises 20x Faster Conversion Speed, compared with ordinary products. What’s more, users are allowed to arrange the playback order according to their demands.
  • High-quality video and audio
DVDFab DVD Creator, attaching great importance to the quality of videos and audio, is designed to create standard Blu-rays of high-definition video (1080p and 720p) and audio (DTS-HD, DTS:X, TrueHD, and TrueHD Atmos) quality. Besides, DVDFab DVD Creator is able to fit in the big screen to offer a theater-like viewing experience.
How to Convert VHS to DVD with DVDFab DVD Creator
Step 1: Launch DVD Creator and load video source (recorded from VHS tape)
convert vhs to dvd
DVDFab VHS to DVD machine supports 3 burn modes: DVD creator, Blu-ray creator and UHD creator.
Step 2: Customize output DVD via menu templates
transfer vhs to dvd
Here you can add external subtitles from Advanced Settings (Wrench icon) and make a stylish DVD menu from the given templates. The font size, color on the navigation menu can be modified as per your personal preference. Meanwhile, decide to convert VHS to DVD-9 or DVD-5.
Step 3: Set destination and start to create DVD
You can burn the recorded video from VHS to a DVD disc, ISO file, or DVD folder. Remember GPU hardware will shorten the whole conversion process. Once done, you can play the created DVD with the best 4k Blu-ray media player and manager, PlayerFab Ultra HD Player.
ROXIO Easy VHS to DVD 3 Plus
Operating system: Windows Vista, Windows 8, Windows 10, Windows XP, Windows 7
Price: $29.9
vhs to dvd service
As one of the best VHS to DVD converters, ROXIO has gained trust and popularity from customers and users for its simple operating instructions and powerful functions.
  • Capture and convert videos with ease
ROXIO Easy VHS to DVD 3 Plus enables users to Convert VHS to DVD in a few easy steps or import video from your camcorder and even convert your analog LPs and cassettes to audio CDs or MP3s. With your capture device connected, you are able to play your video on your camcorder or VCR to capture and convert your video to digital.
  • Edit and enhance videos as your preference
VHS to DVD Plus is more than just a video converter; edit and enhance your video before you export and share it. Users are capable of making quick video edits, trimming videos, cutting video clips, stabilizing shaky video, improving color balance and lighting with easy-to-use controls, and adding titles or rolling credits. There are more functions waiting for you to explore.
  • Create your unique videos
ROXIO Easy VHS to DVD 3 Plus provides videos with the packaging it deserves and burns them to disc with chapters, customizable menus, and themed templates. Users are allowed to split movies across multiple discs.
You could choose to save your treasured stories into DVD, cloud or you are able to upload them to streaming platforms to share the valued memories with others.
How to Convert VHS to DVD with ROXIO Easy VHS to DVD 3 Plus
  1. Connect: Connect your VHS player or camcorder to your PC with an RCA cable and the Roxio capture device.
  2. Capture & Edit: Import and capture video from your device. Users could choose to organize media, trim video, and add titles or transitions.
  3. Share: Burn to DVD with chapters and menus or save to popular formats to share online or to the device.
Is it the best way to convert VHS to digital Walmart? Where to convert VHS to digital in a safe way?
Walmart is a digital delivery point. If you want to gift the conversion recording to someone, you can send the converted VHS to digital Walmart, set the Walmart code and delivery schedule. Then Walmart service provider does the further steps and ensures the delivery on behalf of you.
How much does it cost to burn a VHS tape into a DVD?
The cost for a typical videotape to DVD transfer service ranges from $9.95 to $39.95 per tape. Additional services may cost extra and VHS conversion service should be willing to work with you to create a realistic estimate for your job.
How can I convert VHS tapes without VCR?
If you want to convert your old VHS tape to DVD but don't have a VCR on hand, the only way you can convert the format is by using a video camera that uses VHS tapes. You need some sort of device that can play the video, and a VHS camera is the only other option you have if no VCR is present.
Does Walmart Copy VHS to DVD?
Walmart does convert VHS to DVD through its Photo Departments as of 2022. Customers can either place orders online and send their tapes via mail or visit a local Photo Department yourself. The VHS to DVD conversion service typically takes 3-4 weeks to complete and starts from $12.96 for 30 minutes of video.
This passage provides three best solutions to convert VHS to DVD, ranging from turn to big-name manufacturers for help to complete conversion tasks by yourself. You could choose the most suitable approach to preserve your beautiful memories permanently. Have a try and review these exciting moments with your friends and families.
