Disc to Digital: How to Convert DVD to MP3 Free
Summary: DVD to MP3 converter helps you rip DVD audio to MP3 easily. If you want to know how to convert DVD to MP3 free, choose offline DVD to MP3 converters or online ones in this article to achieve your goal.
- • Copy DVD and Blu-ray files with two backup modes: Full Disc and Main Movie
- • Convert Videos/DVDs/Blu-rays to MKV or MP4 format
- • Work at top speed and export files without quality loss
How to convert DVD to MP3 when you are crazy about a song in a DVD movie? Give the task to DVD to MP3 ripper. DVD to MP3 converters are easily in the market. Some support DVD to MP3 on Windows, some enable you to convert a DVD to MP3 on Mac, others are free as online DVD MP3 ripper. Which way do you want to convert DVD to MP3. Learn about each program in this article for DVD audio to MP3 conversion and choose the best DVD to MP3 converter as your assistant.
Prepare a DVD drive or an external USB DVD drive to insert DVD to PC drive (Window/Mac) ahead no matter which DVD to MP3 converter you choose.
1. How to Convert DVD to MP3 with DVDFab DVD Ripper
The first DVD to MP3 converter I am going to introduce is DVDFab DVD Ripper. It is a free DVD MP3 ripper compatible with Windows and Mac and supporting batch conversion. Want DVD to MP3 free? Just try it. DVDFab DVD Ripper is more than a DVD to MP3 converter. It is also a video converter and allows you to rip DVD to any device like Apple, iPad, Android, etc. With the help of this free software, you can rip DVD to MP4, rip DVD audio to WAV/MP3/OGG, etc., and enjoy your videos/audios on any portable devices. Also, there are “Advanced Settings” and “Video Edit” options offered for you to edit your file.
(1) Steps on how to convert DVD to MP3:
• Download and install DVDFab DVD Ripper (Windows/Mac)
• Select the module of “Ripper” on the top
• Insert your DVD disc or load your file using the “+” icon
• Click “Theater (MKV.Passthrough)” besides “Choose Other Titles” (Custom MP3)
• Click “Audio” and choose “MP3”
• Set an output destination (Mobile Device/Folder/YouTube, Facebook/Vimeo)
• Click the button of “Start” for DVD to MP3 conversion
On the same panel, you can also rip DVD to MP4, MKV, AVI, FLV, M2TS, TS and WMV formats by clicking the button of “Video”. See the option of “Enlarger AI”? It is used to improve video quality by 300%.
Besides, you are allowed to rip DVD to iPad/Apple/Barness&Noble/BlackBerry/Box/Google/HTC, etc., when you click the button of “Device”.
If you want to edit video including its Codec/Frame Rate/Resolution, etc, customize audio and subtitles such as “extract subtitles”, click the option of “Advanced Settings” on the main interface.
If you expect to add Text/Image to your video, adjust its video properties, playback speed, crop or trim it, click the option of “Video Edit” on the main interface of this DVD to MP3 converter before you click the button of “Start”.
“How do I convert a DVD to MP3 on Mac”? Choose DVDFab DVD Ripper as your best assistant. If you still want to play an MP3 on a DVD player, choose DVDFab Player 6. Subsequently, I will list some other programs which re also capable to convert DVD to MP3.
2. How to Convert DVD to MP3 with Apowersoft
• Download this DVD to MP3 converter on Mac
• Click the button of “Add” and load your DVD file
• Set the output audio format as “MP3”
• Decide where to save your file
• Click the button of “Start” and extract audio from DVD free
3. How to Convert DVD to MP3 with AnyMP4 DVD Ripper
• Launch this DVD to MP3 converter on your Mac/Windows
• Hit the button of “Load Disc”
• Use the “Clip” button to edit your file
• Come to the main interface and choose “MP3”
4. How to Convert DVD to MP3 with Format Factory
• Get this DVD to MP3 installed on Windows
• Upload a DVD file through “Add files” option
• Select “Audio” in MP3 format
• Tap “OK” to rip DVD to MP3
5. How to Convert DVD to MP3 with Any Audio Converter
• Work on Windows operation system
• Rip DVD to MP3 and WAV formats
• Click the button of “Add Disc” to load your file
• Set MP3 audio format and destination
• Start to rip audio commentary from DVD
6. How to Convert DVD to MP3 with Wondershare Converter
• Install this DVD to MP3 converter on Windows or Mac
• Load your DVD file (DVD folder/ISO/IFO file)
• Set the option of “Convert all files to” as “Audio - MP3”
• Click “Convert All” to rip DVD to MP3
7. How to Convert DVD to MP3 with VLC
“How do I convert a DVD to MP3 using Windows Media Player”? Before following the steps below, be clear that “Rip a DVD audio to MP3 with VLC media player and the output audio is distorted with bad quality”.
(1) Rip DVD to MP3 with VLC on Windows
• Get VLC launched on your Windows
• Open it and click “Media” in the upper-right corner
• Select “Open Disc”
• Tick off the box before “No disc menus”
• Click the ▼ icon near “Play” in the lower-right corner
• Choose “Convert ALT+O”
• Tap “Profile” > “Audio MP3” in the new panel
• Click the button of “Browse” and input anything in “File name”
• Set an output directory by clicking “Save”
• Start to convert DVD to MP3 VLC
(2) Convert DVD to MP3 with VLC on Mac
There is some differences in DVD to MP3 Mac with VLC
• Launch this DVD to MP3 converter and click “File”
• “Open Disc” > “Disable DVD menus” > Select “Streaming/Saving”
• Click “Settings” > File > “Browse” to name your file “xxx.mp3”
• Click “Save” > Uncheck “Video” and set “Audio” as “MP3”
• Start to rip DVD audio to MP3
8. How to Convert DVD to MP3 with HandBrake + VLC
Rip DVD to MP4 with HandBrake first, and then convert MP4 to MP3 with VLC.
• Download DVD to MP3 converter - HandBrake on Windows
• Insert DVD to your PC’s DVD drive
• Detect your source DVD file in HandBrake
• Set the container format as “MP4” and choose a preferred video resolution
• Click “Browse” and set an output folder
• Start converting DVD to MP4
• Play the MP4 file in VLC media player by “Media/File” > “Convert/Save” > “File” > “Add”
• Click “Convert/Save” button > “Profile” to convert MP4 to MP3
• Set audio directory and click the button of “Start”
If you are using MAC to rip DVD to MP3, uncheck the “Video” box instead.
9. How to Convert DVD to MP3 with Tipard
• Tipard DVD to MP3 converter free download on Windows
• Load DVD disc/folder/IFO files
• Rename you file
• Set the “Start Time” and “End Time”
• Choose output audio format as MP3
• Convert DVD to MP3
10. How to Convert DVD to MP3 Online
Compared with offline DVD to MP3 converters, Online DVD to MP3 ripper’s working speed may be lower and there is an limit on how many DVDs you can convert to MP3.
(1) ZamZar
ZamZar is an online DVD to MP3 converter you can use for this conversion. Head to its official website and open your files > choose the output audio format as MP3 > input your E-mail > start to convert DVD to MP3. It is very easy to use. But compared with offline DVD to MP3 converters, its working speed may be lower and there is an limit on how many DVDs you can convert to MP3.
(2) Apowersoft
This is another online DVD to MP3 converter. You can use it the same way as ZamZar for DVD to MP3 conversion. But there are something you have to keep in mind if you choose it to convert DVD to MP3, or other audio formats like FLAC, WAV, WMA, AAC, etc.
Cons:
• Install Java Applet in advance to convert DVD to MP3 using this online website
• Limited in conversion speed
• Have a high demand for Network
11. Time to Convert DVD to MP3
Time spent in “convert DVD to MP3” depends on such factors:
• DVD size : The bigger your file is, the longer it will take to rip DVD to MP3.
• DVD quality: Th higher your demand is for output quality, the longer it will be.
• DVD player type: The more advanced your DVD player is, the shorter the time will be spent.
• Use of an external DVD drive: It may work slower than an embedded DVD drive.
12. Conclusion
How to convert DVD to MP3 free and easily? There are 12 DVD to MP3 converters recommended, including offline software and online free DVD MP3 ripper. Choose your favorite and start to DVD to MP3 conversion. Among these free programs, DVDFab DV Ripper is highly recommended. It works on Windows/Mac, offers multiple audio/video/device output formats and provides you a video editor. With the help of this DVD to MP3 converter, you can rip DVD to MP3 fast.
